User:OliReadingUK
Revision as of 15:18, 26 May 2011 by OliReadingUK (talk | contribs) (Questions)
Just starting out the world of RepRap, currently pulling together bits for a Prusa Mendel.
Parts
My parts collection so far consists of:
Still need:
  • Stepper motors, probably from astrosyn_excess on ebay
  • Arduino
  • RAMPS (Sanguinololu?)
  • Opto or mechanical end-stops
  • Extruder hot end
I have the following extras from the Prusa parts list, some of which are probably for the extruder:
  • 2 x belt-clamp
  • 2 x bar-clamp
  • 2 x rod-clamp
  • 4 x pla-bushing (total of 16)
Software
Need to download repsnapper, skeinforge and sprinter(firmware)
Questions
Stuff I have to find out about...
  • Recommendations for a power supply? What lines will I need?
Answers I got were:
  • I thought belts were continuous loop but they're not
  • Need to clean up bushings so 8mm rod runs smoothly through
  • 1m of 3mm filament makes 10cc so 100m makes a cubic decimeter
  • Bar should run smoothly through bushings, consider mild heat to bar until it runs smooth
Assorted notes
ABS = tougher, but stinky and hardly enviro-friendly, also takes much higher temps to melt it and almost requires a heated bed. PLA = Compostable, lower temp to work with, but more brittle by comparison and harder to glue.
Experiences
  • Some difficulty getting the bearings into the extruder, had a lot of filing down to do to make them fit
