User:OliReadingUK
Revision as of 13:48, 29 May 2011 by OliReadingUK (talk | contribs)
Just starting out the world of RepRap, currently pulling together bits for a Prusa Mendel.
Parts
My parts collection so far consists of:
- Printed Parts including parts for Wade's Geared Extruder from User:ParCan on http://www.emakershop.com for £75
- Fasteners, Bar and Studding from User:Bob_balthazar on http://www.emakershop.com for £34
- Bearing from User:rsoarer on ebay for £4
- Thick sheet set from genesismachines on ebay for £20
- Belts from alex-par64 on ebay for £16
- Set of 5 NEMA 17 stepper motors (torque not enough for extruder though) from astrosyn_excess on ebay for £36
All prices include postage to UK
Still need:
- Arduino
- RAMPS (Sanguinololu?)
- Mechanical end-stops
- Extruder hot end
- Filament
I have the following extras from the Prusa parts list, some of which are probably for the extruder:
- 2 x belt-clamp
- 2 x bar-clamp
- 2 x rod-clamp
- 4 x pla-bushing
Software
Need to download repsnapper, skeinforge and sprinter(firmware)
Questions
Stuff I have to find out about...
- Recommendations for a power supply? What lines will I need?
Answers I got were:
- I thought belts were continuous loop but they're not
- Need to clean up bushings so 8mm rod runs smoothly through
- 1m of 3mm filament makes 10cc so 100m makes a cubic decimeter
- Bar should run smoothly through bushings, consider mild heat to bar until it runs smooth
- Mechanical end-stops better than opto
Websites
UK
Assorted bits | |
Assorted bits, including extruder hot end |
European
Assorted including electronics |
Assorted notes
- ABS = tougher, but stinky and hardly enviro-friendly, also takes much higher temps to melt it and almost requires a heated bed.
- PLA = Compostable, lower temp to work with, but more brittle by comparison and harder to glue.
- G code looks fun
Experiences
- Some difficulty getting the bearings into the extruder, had a lot of filing down to do to make them fit
