User:OliReadingUK
Revision as of 05:06, 30 May 2011 by OliReadingUK (talk | contribs) (Websites)
Just starting out the world of RepRap, currently pulling together bits for a Prusa Mendel.
Parts
My parts collection so far consists of:
All prices include postage to UK. Currently totaling £392 (including PLA and spare motor)
Still need:
  • Extruder hot end
  • Some bolts for extruder
I have the following extras from the Prusa parts list, some of which are probably for the extruder:
  • 2 x belt-clamp
  • 2 x bar-clamp
  • 2 x rod-clamp
  • 4 x pla-bushing
Software
Need to download repsnapper, skeinforge and sprinter(firmware)
Questions
Stuff I have to find out about...
  • Recommendations for a power supply? What lines will I need?
  • I have a board for the print surface, should I cover it?
Answers I got were:
  • I thought belts were continuous loop but they're not
  • Need to clean up bushings so 8mm rod runs smoothly through
  • 1m of 3mm filament makes 10cc so 100m makes a cubic decimeter
  • Bar should run smoothly through bushings, consider mild heat to bar until it runs smooth
  • Mechanical end-stops better than opto
  • ABS = tougher, but stinky and hardly enviro-friendly, also takes much higher temps to melt it and almost requires a heated bed.
  • PLA = Compostable, lower temp to work with, but more brittle by comparison and harder to glue.
  • G code looks fun
Websites
UK
http://www.reprapcentral.com
Filament
http://www.redwizard3d.com
Assorted bits
http://thingfarm.org
Assorted bits, including extruder hot end
http://www.reprapltd.com
Printed parts
http://www.bitsfrombytes.com
Filament (expensive)
Elsewhere
http://www.reprapsource.com
Assorted including electronics
http://www.emakershop.com
Stuff from assorted countries
http://xyzprinters.com
Lots, mostly kits
http://ultimachine.com
Everything!
Experiences
  • Some difficulty getting the bearings into the extruder, had a lot of filing down to do to make them fit
  • Considered Sanguinololu but went with RAMPS as it's more available and suspect better supported
