User:RobertKuhlmann/RepRap Morgan BOM
< User:RobertKuhlmann
Revision as of 09:05, 23 July 2013 by RobertKuhlmann (talk | contribs) (Printed parts)
Under construcution
This article is the extended version of a material list for the RepRap Morgan.
Please feel free to add missing parts or correct mistakes.
Thanks to Quentin Harley for his permission to do this and for his outstanding Morgan-project.
Printed parts
You find the original SCAD-file from Quentin Harley, that does all parts, over here: Original Morgan SCAD-file
I've redrawn some of the parts to ease modifications without scripting.
01-pvc_pipe_support_a
Socket for PVC-pipe with cable hole
Drawing: 01-pvc_pipe_support_a.pdf
Source (Inventor): 01-pvc_pipe_support_a.ipt
STL-file: 01-pvc_pipe_support_a.stl
Amount needed: 2
02-pvc_pipe_support_b
Socket for PVC-pipe
Drawing: 02-pvc_pipe_support_b.pdf
Source (Inventor): 02-pvc_pipe_support_b.ipt
STL-file: 02-pvc_pipe_support_b.stl
Amount needed: 2
03-z_mount_bottom_8mm
Z-axis base for 8mm axes
Drawing: 03-z_mount_bottom_8mm.pdf
STL-file: 03-z_mount_bottom_8mm.stl
Source (Inventor): 03-z_mount_bottom_8mm.ipt
Amount needed: 1
04-z_mount_top_8mm
z-axis base for 8mm axes
Drawing: 04-z_mount_top_8mm.pdf
Source (Inventor): 04-z_mount_top_8mm.ipt
STL-File: 04-z_mount_top_8mm.stl
Amount needed: 1
05-motormount_short
Motor mount short
Drawing: 05-motormount_short.pdf
Source (Inventor): 05-motormount_short.ipt
STL-file: 05-motormount_short.stl
Amount needed: 1
06-motormount_tall
Motor mount tall
Drawing: 06-motormount_tall.pdf
Source (Inventor): 06-motormount_tall.ipt
STL-file: 06-motormount_tall.stl
Amount needed: 1
07-drivewheel_rod
Drivewheel for rod
Drawing: 07-drivewheel_rod.pdf
Source (Inventor): 07-drivewheel_rod.ipt
STL-file: 07-drivewheel_rod.stl
Amount needed: 1
08-drivewheel_tube
Drivewheel for tube
Drawing: 08-drivewheel_tube.pdf
Source (Inventor): 08-drivewheel_tube.ipt
STL-file: 08-drivewheel_tube.stl
Amount needed: 1
09-22mm_6805_bearing_adaptor
Adapter 6805er-Lager auf 22mm
Drawing: 09-22mm_6805_bearing_adaptor.pdf
Source (Inventor): 09-22mm_6805_bearing_adaptor.ipt
STL-file: 09-22mm_6805_bearing_adaptor.stl
Amount needed: 1
10-bed_arm_left_8mm
Bed arm left for 8mm rod
Drawing: 10-bed_arm_left_8mm.pdf
Source (Inventor): 10-bed_arm_left_8mm.ipt
STL-file: 10-bed_arm_left_8mm.stl
Amount needed: 1
11-bed_arm_right_8mm
Bed arm right for 8mm rod
Drawing: 11-bed_arm_right_8mm.pdf
Source (Inventor): 11-bed_arm_right_8mm.ipt
STL-file: 11-bed_arm_right_8mm.stl
Amount needed: 1
12-bed_z_mount_bracket
Bed bracket for z-axis
Drawing: 12-bed_z_mount_bracket.pdf
Source (Inventor): 12-bed_z_mount_bracket.ipt
STL-file: 12-bed_z_mount_bracket.stl
Amount needed: 1
13-bed_rear_mountclips
Rear clips for bed mounting
Drawing: 13-bed_rear_mountclips.pdf
Source (Inventor): 13-bed_rear_mountclips.ipt
STL-file: 13-bed_rear_mountclips.stl
Amount needed: 2
14-bed_front_mountclips.stl
Front clips for bed mounting
Drawing: 14-bed_front_mountclips.pdf
Source (Inventor): 14-bed_front_mountclips.ipt
STL-file: 14-bed_front_mountclips.stl
Amount needed: 2
15-hall_endstop_holder
Hall-effect end stop sensor holder
Drawing: 15-hall_endstop_holder.pdf
Source (Inventor): 15-hall_endstop_holder.ipt
STL-File: [1]
Amount needed: 3
16-leadscrew_shaft_motor_mount
Leadscrew to motor shaft adaptor
Drawing: 16-leadscrew_shaft_motor_mount.pdf
Source (Inventor): 16-leadscrew_shaft_motor_mount.ipt
STL-file: 16-leadscrew_shaft_motor_mount.stl
Amount needed: 1
17-Morgan_arm_PSI_a
Morgan arm PSI a with cable holes
Drawing: 17-Morgan_arm_PSI_a.pdf
Source (Inventor): 17-Morgan_arm_PSI_a.ipt
STL-file: 17-Morgan_arm_PSI_a.stl
Amount needed: 1
18-Morgan_arm_PSI_b
Morgan arm PSI b with cable holes
Drawing: 18-Morgan_arm_PSI_b.pdf
Source (Inventor): 18-Morgan_arm_PSI_b.ipt
STL-file: 18-Morgan_arm_PSI_b.stl
Amount needed: 1
19-Morgan_arm_Theta_a
Morgan-Arm Theta a
Drawing: 19-Morgan_arm_Theta_a.pdf
Source (Inventor): 19-Morgan_arm_Theta_a.ipt
STL-file: 19-Morgan_arm_Theta_a.stl
Amount needed: 1
20-Morgan_arm_Theta_b
Morgen-Arm Theta b
Drawing: 20-Morgan_arm_Theta_b.pdf
Source (Inventor): 20-Morgan_arm_Theta_b.ipt
STL-File: 20-Morgan_arm_Theta_b.stl
Amount needed: 1
21-Morgan_toolhead
Toolhead
Drawing: 21-Morgan_toolhead.pdf
Source (Inventor): 21-Morgan_toolhead.ipt
STL-file: 21-Morgan_toolhead.stl
Amount needed: 1
21-Morgan_toolhead_V3 (alternative)
Base for the V3 bowden hotend from RepRap-Fab.org.
Drawing: 21-Morgan_toolhead_V3.pdf
Source (Inventor): 21-Morgan_toolhead_V3.ipt
STL-file: 21-Morgan_toolhead_V3.stl
Amount needed: 1
22-Leadscrew-nut_Alpen8mmSDS
Leadscrew nut for Alpen 8mm SDS axis (drill)
Drawing: 22-Leadscrew-nut_Alpen8mmSDS.pdf
Source (Inventor): 22-Leadscrew-nut_Alpen8mmSDS.ipt
STL-file:22-Leadscrew-nut_Alpen8mmSDS.stl
Amount needed: 1
23-extruder_bowden_adaptor
Bowden adaptor for extruder
Drawing: 23-extruder_bowden_adaptor.pdf
Source (Inventor): 23-extruder_bowden_adaptor.ipt
STL-file: 23-extruder_bowden_adaptor.stl
Amount needed: 1
24-Morgan_Spool_holder
Holder for filament spool
Drawing:24-Morgan_Spool_holder.pdf
Source (Inventor) : 24-Morgan_Spool_holder.ipt
STL-file: 24-Morgan_Spool_holder.stl
Amount needed: 1
Cap_2
Cap with 8mm hile and 16mm thread
Drawing: Cap_2.pdf
Source (Inventor): Cap_2.ipt
STL-file: Cap_2.stl
Amount needed: 2
Eckstruder_Big_Gear_Herringbone
Big extruder gear with fishbone shaped teath
Drawing: Eckstruder_Big_Gear_Herringbone.pdf
Source (Inventor): Eckstruder_Big_Gear_Herringbone.ipt
STL-file: Eckstruder_Big_Gear_Herringbone.stl
Amount needed: 1
Eckstruder_Block_for_Prusa
Prusa-Extruderblock
Drawing: []
Source (Inventor): []
Amount needed: 1
Eckstruder_Idler_Block_for_Prusa
Prusa-Zwischenrad-Block
Drawing: []
Amount needed: 1
Eckstruder_Small_Gear_Herrinbone
Kleines Fischgrätgetriebezahnrad für den Extruder
Drawing: []
Amount needed: 1
thumb_knob_M4_extruder
Noppenmutter M4 für den Extruder
Drawing: []
Amount needed: 1
TighteningCone_2
Konische Befestigungsklemme
Drawing: []
Amount needed: 2
Hardware
M3 nut
M3 grub screw 6mm (or suitable replacement bolt
M4 nut
M4 bolt 40mm
M4 bolt 80mm
M8 nut
M8 washer
M8 spring washer
M8 washer 28mm
M8 Nylock Nut
M8 Bolt 40mm
M8 Bolt 100mm
M8 Bolt 60mm
2mm self tapping coach screws, 40mm
15mm brass pipe 440mm
15mm brass pipe 200mm
22mm brass pipe 460mm
8mm threaded rod 650mm
8mm smooth rod
hard spring (idler compression) 7mm
8mm soft spring (lead screw anti backlash)
cabinet coach screws, 5mm
