User:Scottlawsonbc
Revision as of 02:03, 20 August 2014 by Scottlawsonbc (talk | contribs) (cat test (by SublimeText.Mediawiker))
Lawson Documentation
Lawson
Release status: concept
Lawson is a printer designed to have high accuracy, precision, and mechanical stiffness.
Introduction
Lawson is a 3D printer designed to have accuracy, precision, and mechanical stiffness. Components can be substituted to tailor the printer for higher accuracy and precision, or to lower build costs. Cat test
Features
  • Stiff, rigid frame with no play
  • High accuracy and precision
  • Mechanical components can be purchased from two suppliers, minimizing the reliance on a middleman supplier.
  • Components can be substituted to achieve higher quality or lower build costs, appealing to a wide audience.
Specifications
Component λ Variant ϵ Variant
Mechanical parts (exc. motors, electronics, screws) 26 26
Printed parts (exc. motors, electronics, screws) 0 17
Hardware Cost (exc. motors, electronics, screws) $443.41 $369.52
Controller Electronics Almost all RepRap Almost all RepRap
Printing Size 200 x 200 x 240 200 x 200 x 240
Motors 4x NEMA-17 Stepper, 1x NEMA-23 5x NEMA-17 Stepper
Pro High accuracy, speed, stiffness Lower cost, high speed
Con Higher cost Lower mechanical stiffness and accuracy
Printed Parts
A number of Lawson components can be 3D printed instead of purchased. However, unlike other 3D printers such as the Prusa i3 and MendelMax, all printed components in the Lawson have off-the-shelf purchasable substitutes. This was done for two reasons. The first reason is that you can obtain higher mechanical stiffness by using metal components instead of printed components, although printed components are still effective. The second reason is that having a purchasable version of each part makes the design more accessible, minimizing the reliance on outside suppliers.
High precision design
The lead screws and linear rail are some of the Lawson's most expensive components. While cheaper components are available, the lead screws are critical to ensuring high accuracy, and the linear rail is key to making the print bed mechanically stiff. Other designs, such as the Prusa i3 or MendelMax 2.0, do not have the same mechanical stiffness that the Lawson printer has.
Frame type
Single Sheet Frame
Wood Sheet frame
Stepper Motors
The Lawson can use either 5x NEMA 17 or 4x NEMA 17 + 1x NEMA 23. Unless cost is an issue, it is recommended to use 4x NEMA 17 + 1x NEMA 23. Using a NEMA 23 will simplify the construction of the Y-axis while also increasing its performance characteristics.
Electronics
Almost all RepRap electronics such can be used to control the Lawson. Electronics confirmed to be working include the RUBMA Board, Printrboard, GEN7, RAMPS, and Rambo board.
