User talk:Jamesdanielv
I think this is the page you want to edit: http://reprap.org/wiki/Mendel_Variations/Catalyst
Here is some of your old text: http://reprap.org/mediawiki/index.php?title=Category%3AMendel_RepStrap&diff=15047&oldid=15046
Good luck. Ask in a forum for help if you get stuck.
--Sebastien Bailard 08:58, 21 April 2010 (UTC)
Hi James, I've moved your new project to Exquisite_Automated_Build_Platform. Hope that's ok. :D --Sebastien Bailard 08:36, 9 January 2011 (UTC)
thank you
Thank you for making the RepRap wiki better.
In particular, thank you for making the jy-mcu page. I found it useful for a completely unrelated project :-). --DavidCary (talk) 11:04, 20 February 2014 (PST)
thanks for edits and cleaning the page DavidCary, just be sure to leave the contact information of the development stub on the right side of page. changes are still being made to code and format of page. I want people to be able to contact me with suggestions.
Hi James,
Thanks for the comment "apparently using ftdi chip, but not recommended" on my new section "A simple way to change BT module settings" on JY-MCU page.
Question: what is "not recommended" referred to? To the missing resistors (potential communication problems and some risk to destroy the BT module) or to the concept itself of using the FTDI chip?
hello, this is competing logic signals at a time. one from the ftdi chip, and one from the arduino, and one from the BT module. if the arduino was to talk, like it does when bootloader is being programmed, or when powered up then the load of the other device connected to it would be great, and possibly blow the arduino channel or the bt channel, or the fdti chip channel. since the power from usb is limited to less than 500ma, i would suspect that is why nothing has blown yet, but it places the current draw ridiculously out of spec at the very least for arduino. from my memory current draw per channel spec is 100ma, and per port it is 150ma max. if the device was plugged in and running from another source that does not have current overload protection, i would suspect a blown channel, a damaged serial ic chip, or a blown bt module. the bt module does have built it resistors.
