User talk:Kkronyak
Revision as of 19:24, 17 February 2015 by Kkronyak (talk | contribs) (Source files)
Source files
Hi there,
I'm interested in adding another extruder or two or three to my printer and your board looks like a good place to start. The link for the source files seems to take me to an upload page. Am I being thick? Do you have any boards available to buy?
Response
I'm not sure what happened to the source files. I will see if I can find and upload them. I did a small run of boards so I could probably send one including all parts required to populate it if desired. The original design had a minor flaw but I resolved it in an updated version of the Eagle files and made a manual correction on the small run of boards.
If you just want to go dual the easiest route might be to use RAMPS unless you have a particular need for using the Sanguinololu controller -- in my case it was to keep it inside the frame of the machine but I have since built a new one. This add-on board can also be connected to RAMPS to allow for triple-extrusion.
If I can find the files I will post them here. If you want one of my manufactured PCBs please send me an email with the link below.
Special:EmailUser/Kkronyak
