Viki LCD
Revision as of 06:15, 30 December 2014 by Glenn (talk | contribs) (-tag)
Viki LCD
i2c LCD control with SD slot
CC SA 3.0
ViKi is an easy to use LCD control panel interface designed for 3D printers and CNC machines but can also be used for other micro controller projects. It allows your 3D printer to operate without a PC always connected and provides visual indication of things like temperature and peripheral activity. It can also be used on most micro controller / Arduino projects that require a display and control interface. Give that project of yours a professional looking panel!
ViKi stands for Visual Kinetic control Interface.
Viki LCD is based on AdaFruit's RGB LCD Shield and is compatible with the same Arduino library that is uses. Lincomatic also has the faster LIQUIDTWI2 LCD library with support for ViKi.
... to be continued..
