Web4Deb extruder
Revision as of 23:17, 13 December 2010 by Capo (talk | contribs) (Introduction)
Introduction
The Web4Deb Extruder is a functional auger based granular extruder that produces perforated HDPE strips for use in aquaponics. A video of the extruder in action can be found [here]. The blog of the creator (Web4Deb) can be found [here].
Specifications
  • The barrel is heated with a length of Nichrome wire and and insulated with what appears to be polyimide tape.
  • The auger is a standard 3/4" wood auger bit (bought a set from Harbor Freight) and cut it down to length.
  • The auger is driven by a wind shield wiper motor which is geared down with a bicycle chain and sprocket.
  • The heating element draws around 16A at 12V (192W) from a computer power supply.
  • The temperature for the extruder barrel is controlled with a Teensy AVR micro-controller.
  • The die is appears to be interchangeable.
  • The extruded HDPE is forced through a set of fan cooled rollers.
  • Two individual temperature sensors are located on the extrusion barrel.
  • The Teensy AVR micro-controller appears to be used to switch one or more relays through a transistor array.
The extruder Setup
The micro-controller setup
Questions
  • How far does the auger drill bit extend into the extruder barrel?
  • what is the RPM of the auger while extruding?
  • What type of thermistor is used for the temperature sensing?
  • Is it really required that the temperature be measured in two places?
  • Is there two separate windings of nichrome wire that are individually controllable?
  • What RPM is are the pinch wheels running at?
  • How are the pinch wheels powered?
Further information
Do you have some inside knowledge? Post it here!
