Witbox Diamond
Revision as of 09:17, 21 September 2015 by RepRap.me (talk | contribs) (Created page with "{{Development <!--Header--> |name = Witbox Diamond |status = page under construction <!--Image--> |image = Diamond_Hotend_Nozzle.jpg <!--General--> |description = bq Witbox Di...")
Witbox Diamond
Release status: page under construction
bq Witbox Diamond
unknown
This page is under construction: Estimated time of completion (state content useable): one week.
The intention of this page is to serve as a build guide for those who want to modify a bq Witbox for the triple extruder solution Diamond Hotend
Part list
Witbox Diamond main parts
  • 1 x Diamond Nozzle for 1.7 mm filament
  • 1 x Witbox Diamond Cooling Shield (printed part)
  • 1 x Witbox Diamond X-carriage (printed part)
  • 3 x Thermal insulator sheet
  • 1 x Thermal compound
  • 1 x Heater cartridge
  • 1 x Thermistor NTC 100k wired
  • 3 x E3D LiteV6 with bowden fittings
  • 1 x Axial fan (12 volt / 50mm / 18 CFM)
  • 4 x Cable tie
  • 4 x M3 nut
  • 1 x M4 nut
  • 4 x M3x20 CSK til 50 mm axial fan
  • 3 x M3x10 CSK
  • 1 x M4x30 CSK
  • 2 x Male 2P 2.54 mm (pin header or Molex KK or Dupont)
  • 1 x Heat shrink
Bowden extruder kit
  • 3 x Bowden tube OD:4/ID:2/L:650 mm
  • 3 x MK9 extruder
  • 3 x extrudermount ”laser” version (printed part)
  • 3 x extruder motor cable
  • 1 x Lasercut extruder mount
  • 1 x Braided sleeve 20 cm
  • 1 x Cable tie mount
  • 2 x Cable tie
  • 1 x Filament roll holders kit (printed part: 2+1 parts)
Endstop
  • 1 x Z-endstop adapter (printed part)
  • 2 x M3 nut
  • 2 x M3x6 bolt
Elektronics
  • 1 x Easy Expander X1
  • 2 x Stepsticks
  • 4 x Adhesive PCB spacer (RS: 220-787)
  • 10 x Cable tie (estimered number)
  • 2 x Wire from PSU to Easy Expander
  • 1 x 2x5P IDC cable from Ramps AUX-2 to Easy Expander
Assembling
-- under construction --
