Witbox Diamond
Witbox Diamond
Release status: page under construction
Description | bq Witbox Diamond
License | unknown
Author | |
Contributors | |
Based-on | |
Categories | RepRap Diamond Hotend
CAD Models | |
External Link |
This page is under construction: Estimated time of completion (state content useable): one week.
The intention of this page is to serve as a build guide for those who want to modify a bq Witbox for the triple extruder solution Diamond Hotend
Part list
Witbox Diamond main parts
- 1 x Diamond Nozzle for 1.7 mm filament
- 1 x Witbox Diamond Cooling Shield (printed part)
- 1 x Witbox Diamond X-carriage (printed part)
- 3 x Thermal insulator sheet
- 1 x Thermal compound
- 1 x Heater cartridge
- 1 x Thermistor NTC 100k wired
- 3 x E3D LiteV6 with bowden fittings
- 1 x Axial fan (12 volt / 50mm / 18 CFM)
- 4 x Cable tie
- 4 x M3 nut
- 1 x M4 nut
- 4 x M3x20 CSK til 50 mm axial fan
- 3 x M3x10 CSK
- 1 x M4x30 CSK
- 2 x Male 2P 2.54 mm (pin header or Molex KK or Dupont)
- 1 x Heat shrink
Bowden extruder kit
- 3 x Bowden tube OD:4/ID:2/L:650 mm
- 3 x MK9 extruder
- 3 x extrudermount ”laser” version (printed part)
- 3 x extruder motor cable
- 1 x Lasercut extruder mount
- 1 x Braided sleeve 20 cm
- 1 x Cable tie mount
- 2 x Cable tie
- 1 x Filament roll holders kit (printed part: 2+1 parts)
Endstop
- 1 x Z-endstop adapter (printed part)
- 2 x M3 nut
- 2 x M3x6 bolt
Electronics
- 1 x Easy Expander X1
- 2 x Stepsticks
- 4 x Adhesive PCB spacer (RS: 220-787)
- 10 x Cable tie (estimered number)
- 2 x Wire from PSU to Easy Expander
- 1 x 2x5P IDC cable from Ramps AUX-2 to Easy Expander
Assembling
-- under construction --
