Wood-D Extruder Drive
Revision as of 03:13, 24 April 2014 by JKDesign (talk | contribs)
Just another wooden bowden extruder for 3D-Delta-Printer (Open Source Project)
GPL v3
CorelDraw / PDF
Wood-D - Just another wooden 3D-Delta-Printer (Open Source Project)
Wood-D Extruder Drive is a simple bowden extruder based on LASER-cutted plywood or MDF or acrylic for 1.75 mm filament.
Design Objectives
Specifications
Principle Bowden extruder like Wade's Geared Extruder
Construction LASER cut 4mm plywood or MDF (1 piece 102 x 295 mm) (also acrylic can be used)
Drive Gear driven hobbed bolt with NEMA 17 stepper motor
Filament for 1.75 mm (Little redesign for 3 mm)
Dimension 100 x 60 x 32(+Gears) mm
Features
Based on the LASER cut constructive parts you get a very high precision at easy assembling.
The plywood parts/puzzle are hold together with key and slots and a little bit of glue. Through the box design with cross bracing the stiffness is very high.
All non-plywood parts are standard industrial parts you can be bought from online shops or eBay.
Easy assembling - only drive shafts and threaded rods have to be sawed.
Necessary tools: LASER cutter (visit a FabLab/Hackerspace in your area), hand saw for metal, screw drivers, gripper, cutter, soldering iron
Parts
Case
LASER cut 4 mm plywood or MDF or acrylic
Drive
Hobbed bolt M8 x 60 (as in Wade's Geared Extruder) OR a hobbed shaft with M8 on both ends.
Meantime you get industrial made shafts of hardened steel.
Gears
Standard industrial gears 72+24 module 0.8 OR RepRap printed gears from Wade's Geared Extruder
Note: The 72 tooth industrial gear has to be widened to 8 mm or M8
Note: The different gears needs different settings in firmware (industrial: 72/24; RepRap: 39/11)
Motor
NEMA 17 stepper motor as usual in RepRap projects
Bill of Materials
Quantity Description Type Comments Diagram
1 4 mm plywood or MDF or acrylic with min. 102 x 295 mm LASER
1 Hobbed bolt M8 x 60 (as in Wade's Geared Extruder) Shop
 ? Washer M8 Hardware to center the hobbed position
1 Plastic gear 72 tooth module 0.8 (has to be widened to 8 mm or M8) Shop
(1) Alternative: RepRap big gear 39 tooth from Wade's Geared Extruder RP 39t17p.jpg
1 Plastic gear 24 tooth module 0.8 Shop
(1) Alternative: RepRap small gear 11 tooth from Wade's Geared Extruder RP 11t17p.jpg
2 Ball bearing with flange F608ZZ Shop
1 Ball bearing 605ZZ Shop
1 Steel shaft 5 mm with length 34 mm Shop recommended: shaft with ground surface
1 Steel shaft 5 mm with length 17 mm Shop recommended: shaft with ground surface
2 Pneumatic bulkhead connector/fitting for 4 mm tube Shop
1 PTFE (Teflon™) 4/2 mm tube with length about 2x 30 mm Shop same as to hot end
2 Threaded rod M4 with length about 100 mm Hardware length depends on spring
4 Nut M4 Hardware
4 Screw M3 x 8 Hardware
4 Washer M3 Hardware
2 Wing nut M4 Hardware
(2) Alternative: knurled nut M4 Hardware
(2) Alternative: nut M4 glued in wooden star knob LASER wooden parts for star knob are in new LASER cut files
2 Spring 7 x 5.4 X 35 (or similar) Hardware nearly any spring with an inner diameter greater than 4 mm
1 NEMA 17 stepper motor Shop
Casein glue for wooden parts
2 Component glue (Epoxy) for nuts on the threaded rods and the gear on the stepper motor
Downloads
Design and LASER cut files at GitHub repository github.com/jkDesignDE/Wood-D
Tutorial
Assembling tutorial as image sequence at wood-d.de/tutorial-wood-d-extruder-drive
Links
More infos about the Wood-D project on the blog page wood-d.de (German language)
