YARR
Revision as of 18:04, 18 March 2016 by Ledsandchips (talk | contribs)
YARR - Yet Another RepRap
Description | |
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Introduction
- YARR (Yet Another RepRap) is an open source 3D printer designed and developed by LEDs&Chips Creative Electronics. YARR is based on the CoreXY technique [1]and adds several improvements to other printers.
- Where to buy
- Leds & Chips Assembled - Portugal
Technical specifications
Dimensions
Custom-Sized
Built Version 7575
- Printer Dimensions: 1250(X) x 1250(Y) x 1250 mm(Z without bowden tupe support)
- Print Area Dimensions: 750(X) x 750(Y) x 750 mm(Z)
Built Version 5050
- Printer Dimensions: 1000(X) x 1000(Y) x 1000 mm(Z without bowden tupe support)
- Print Area Dimensions: 500(X) x 500(Y) x 500 mm(Z)
Mechanical Construction
- OpenBuilds V-Slot aluminium frame
- OpenBuilds Wheels carriages X, Y, Z
- 4 motors Z Axis
- Flexible aluminium coupling for threaded rods of Z Axis
- 9 point print base levelling system with cushioning
- Quick change system for multi tools head
- Brushless Fans with axial ball bearings.
Print resolution
- Very high: 60 microns
- High 100 microns
- Medium 200 microns
- Low 300 microns
Extruder Mechanics
- Custom extruder design
- 0.4mm nozzle
- Heat-sinks with axial fan
- Part cooling nozzle
Print speed
- -Recommended speed: 70 mm / s
- -Maximum recommended speed: 200 mm / s
Electronics
- Any RepRap electronics conforming to RepRap Interface Standard RIS 1. Default: RAMPS 1.4
- LCD Panel with rotary encoder and push-button navigation for autonomous printing
- Cold glass base (size:750 x 750 x 4 mm)
- Power supply: 220 AC 12 DC 100W
- Thermistor 100k EPCOS
- Heating element: 12V 40W
Software
- Firmware derivative Marlin
- Recommended environment: Cura Software
- Supported Files:. Gcode
- OS supported:
- Windows XP and above
- Mac OS X and above
- Linux
Communications
- Standard SD card reader
- USB Port Type B
Materials
- PLA Filament 1.75-mm
