Yet Another RepRap Host
Revision as of 15:17, 6 November 2013 by Macon (talk | contribs) (Created page)
YARRH is a combined G-Code compiler and RepRap driver. It is designed for simplicity from the ground up, providing a streamlined CAM Toolchain in one program. Wuflnor (Arkadiusz Śpiewak) wrote it entirely in C++ and Qt, so that it can be installed from single .exe file (available here). The original source code is available here on GitHub, along with a readme containing the following claims:
  • 3D view of printed object
  • 3D compose table
  • easy manipulation of objects
  • edditing group of objects at once
  • layer view for single and all layers
  • calibration procedures for printer with automatic stepps per mm calculations
  • integreated ui for slic3r
  • predefined configs for slicing
  • easy to use intuitive GUI
  • one file download, no dependencies, just install and use
More information can be found on this thread in the RepRap forums, in this Hack-A-Day article, and in numerous YouTube videos on the software. The installation files are also double-listed on GitHub, although the most recient versions are missing.
