Archim2 development
Related Pages: Archim v1.0 .:. Archim v1 Development .:. Archim v2.0 .:. Archim v2 Development .:. RAMBo
Archim Pages: Archim v1.0 .:. Archim1 Development
This page contains information relevant to the development of Archim 2. You can find general info at Archim_v2.0.
Processor Pins
Physical_Pin | Pin_Name | Digital_Pin | Marlin_Function |
27 | PA8 | 0 | |
2 | PA9 | 1 | |
144 | PB25 | 2 | SDCARDDETECT |
139 | PC28 | 3 | MOTOR_CURRENT_PWM_E0_PIN |
137 | PC26 | 4 | FAN_PIN |
136 | PC25 | 5 | FAN2_PIN |
135 | PC24 | 6 | HEATER_0_PIN |
134 | PC23 | 7 | HEATER_1_PIN |
133 | PC22 | 8 | HEATER_2_PIN |
132 | PC21 | 9 | HEATER_BED_PIN |
102 | PC29 | 10 | MOTOR_CURRENT_PWM_Z_PIN |
20 | PD7 | 11 | MOTOR_CURRENT_PWM_E1_PIN |
21 | PD8 | 12 | MOTOR_CURRENT_PWM_Y_PIN |
68 | PB27 | 13 | BTN_EN2 |
17 | PD4 | 14 | X_MIN_PIN |
18 | PD5 | 15 | Y_MAX_PIN |
6 | PA13 | 16 | BTN_ENC |
5 | PA12 | 17 | LCD_PINS_RS |
4 | PA11 | 18 | E1_ENABLE_PIN |
3 | PA10 | 19 | E1_TMC2130_CS |
86 | PB12 | 20 | |
87 | PB13 | 21 | |
1 | PB26 | 22 | E1_STEP_PIN |
7 | PA14 | 23 | BEEPER |
8 | PA15 | 24 | LCD_PINS_ENABLE |
13 | PD0 | 25 | E1_DIAG_PIN |
14 | PD1 | 26 | TMC_SWSPI_MISO_PIN |
15 | PD2 | 27 | TMC_SWSPI_SCK_PIN |
16 | PD3 | 28 | TMC_SWSPI_MOSI_PIN |
19 | PD6 | 29 | Y_MIN_PIN |
22 | PD9 | 30 | Z_MAX_PIN |
26 | PA7 | 31 | Z_MIN_PIN |
32 | PD10 | 32 | X_MAX_PIN |
55 | PC1 | 33 | |
59 | PC2 | 34 | LCD_PINS_D7 |
60 | PC3 | 35 | |
116 | PC4 | 36 | Z_DIAG_PIN |
63 | PC5 | 37 | X_DIR_PIN |
64 | PC6 | 38 | X_STEP_PIN |
65 | PC7 | 39 | X_TMC2130_CS |
66 | PC8 | 40 | |
67 | PC9 | 41 | X_ENABLE_PIN |
71 | PA19 | 42 | |
72 | PA20 | 43 | |
101 | PC19 | 44 | Z_ENABLE_PIN |
100 | PC18 | 45 | Z_TMC2130_CS |
99 | PC17 | 46 | Z_STEP_PIN |
98 | PC16 | 47 | Z_DIR_PIN |
97 | PC15 | 48 | Y_DIAG_PIN |
96 | PC14 | 49 | Y_ENABLE_PIN |
95 | PC13 | 50 | Y_TMC2130_CS |
94 | PC12 | 51 | Y_STEP_PIN |
92 | PB21 | 52 | |
140 | PB14 | 53 | |
78 | PA16 | 54 | LCD_PINS_D5 |
79 | PA24 | 55 | |
80 | PA23 | 56 | |
81 | PA22 | 57 | |
82 | PA6 | 58 | MOTOR_CURRENT_PWM_X_PIN |
83 | PA4 | 59 | X_DIAG_PIN |
84 | PA3 | 60 | BTN_EN1 |
85 | PA2 | 61 | |
88 | PB17 | 62 | |
89 | PB18 | 63 | |
90 | PB19 | 64 | |
91 | PB20 | 65 | |
76 | PB15 | 66 | |
77 | PB16 | 67 | |
24 | PA1 | 68 | LCD_PINS_D6 |
23 | PA0 | 69 | LCD_PINS_D4 |
9 | PA17 | 70 | |
70 | PA18 | 71 | |
103 | PC30 | 72 | |
107 | PA21 | 73 | |
108 | PA25 | 74 | |
109 | PA26 | 75 | |
110 | PA27 | 76 | |
111 | PA28 | 77 | |
142 | PB23 | 78 | E0_DIAG_PIN |
129 | PB11 | 85 | |
112 | PA29 | 87 | SDSS |
93 | PC11 | 92 | Y_DIR_PIN |
115 | PB2 | 93 | |
114 | PB1 | 94 | |
113 | PB0 | 95 | |
117 | PC10 | 96 | E0_DIR_PIN |
143 | PB24 | 97 | E1_DIR_PIN |
122 | PB7 | 98 | |
121 | PB6 | 99 | |
123 | PB8 | 100 | |
120 | PB5 | 101 | |
119 | PB4 | 102 | |
118 | PB3 | 103 | E0_TMC2130_CS |
131 | PC20 | 104 | E0_ENABLE_PIN |
141 | PB22 | 105 | |
138 | PC27 | 106 | |
128 | PB10 | 107 | E0_STEP_PIN |
10 | VDDCORE | ||
11 | VDDIO | ||
12 | GND | ||
33 | GNDPLL | ||
34 | VDDPLL | ||
35 | XOUT | ||
36 | XIN | ||
37 | DHSDP | ||
38 | DHSDM | ||
39 | VBUS | ||
40 | VBG | ||
41 | VDDUTMI | ||
42 | DFSDP | ||
43 | DFSDM | ||
44 | GNDUTMI | ||
45 | VDDCORE | ||
46 | JTAGSEL | ||
47 | NRSTB | ||
48 | XIN32 | ||
49 | XOUT32 | ||
50 | SHDN | ||
51 | TST | ||
52 | VDDBU | ||
53 | FWUP | ||
54 | GNDBU | ||
25 | PA5 | undef | |
28 | PB28 | undef | |
29 | PB29 | undef | |
30 | PB30 | undef | |
31 | PB31 | undef | |
127 | PB9 | undef | |
130 | PC0 | undef | |
56 | VDDOUT | ||
57 | VDDIN | ||
58 | GND | ||
61 | VDDCORE | ||
62 | VDDIO | ||
69 | NRST | ||
73 | VDDANA | ||
74 | GNDANA | ||
75 | ADVREF | ||
104 | VDDCORE | ||
105 | VDDIO | ||
106 | GND | ||
124 | VDDCORE | ||
125 | VDDIO | ||
126 | GND |
The physical pin number and pin name is information from the sam3x datasheet (4.2.3 144-lead LQFP Pinout)
The digital pin number is generated from the Archim Core from the file variant.cpp
Note: Digital Pin numbers above 91 are extended by the Archim arduino addons.
