EinsyRambo development
RAMBo Pages: RAMBo .:. RAMBo v1.0-1.1 .:. RAMBo v1.2 .:. RAMBo v1.3 .:. RAMBo v1.4 .:. RAMBo Firmware .:. RAMBo Development .:. MiniRambo .:. MiniRambo Development .:. EinsyRambo .:. EinsyRambo Development
This page contains information relevant to the development of the EinsyRambo PCB. You can find general info at EinsyRambo.
Pins
The extension headers are in the format "Extension Name" "Pin Number" "Function". Example: MX1-5 Direction = "Motor Extension 1" "Pin 5".
Pin Number | Pin Number | Arduino Pin Name | Function |
1 | PG5 ( OC0B ) | Digital pin 4 (PWM) | Bed Heater |
2 | PE0 ( RXD0/PCINT8 ) | Digital pin 0 (PWM) (RX0) | USB – serial comms |
3 | PE1 ( TXD0 ) | Digital pin 1 (PWM) (TX0) | USB – serial comms |
4 | PE2 ( XCK0/AIN0 ) | RamboDigital pin 78 | |
5 | PE3 ( OC3A/AIN1 ) | Digital pin 5 (PWM) | P2 1 |
6 | PE4 ( OC3B/INT4 ) | Digital pin 2 (PWM) | nAC_FAULT, J19 3 |
7 | PE5 ( OC3C/INT5 ) | Digital pin 3 (PWM) | Heat 0 |
8 | PE6 ( T3/INT6 ) | RamboDigital pin 79 | |
9 | PE7 ( CLKO/ICP3/INT7 ) | RamboDigital pin 80 | |
10 | VCC | VCC | VCC |
11 | GND | GND | GND |
12 | PH0 ( RXD2 ) | Digital pin 17 (RX2) | P3 5 |
13 | PH1 ( TXD2 ) | Digital pin 16 (TX2) | P3 3 |
14 | PH2 ( XCK2 ) | RamboDigital pin 84 | P1 10 (LCD Beeper) |
15 | PH3 ( OC4A ) | Digital pin 6 (PWM) | Fan 2 |
16 | PH4 ( OC4B ) | Digital pin 7 (PWM) | |
17 | PH5 ( OC4C ) | Digital pin 8 (PWM) | Fan 1 |
18 | PH6 ( OC2B ) | Digital pin 9 (PWM) | P1 9 (LCD BTN Click) |
19 | PB0 ( SS/PCINT0 ) | Digital pin 53 (PWM)(SPI-SS) | J19 5 |
20 | PB1 ( SCK/PCINT1 ) | Digital pin 52 (PWM)(SCK) | P2 9, J19 11 |
21 | PB2 ( MOSI/PCINT2 ) | Digital pin 51 (PWM)(MOSI) | P2 5, J19 12 |
22 | PB3 ( MISO/PCINT3 ) | Digital pin 50(MISO) | P2 10, J19 9 |
23 | PB4 ( OC2A/PCINT4 ) | Digital pin 10 (PWM) | Z Min Endstop |
24 | PB5 ( OC1A/PCINT5 ) | Digital pin 11 (PWM) | Y Min Endstop |
25 | PB6 ( OC1B/PCINT6 ) | Digital pin 12 (PWM) | X Min Endstop |
26 | PB7 ( OC0A/OC1C/PCINT7 ) | Digital pin 13 (PWM) | LED |
27 | PH7 ( T4 ) | RamboDigital pin 85 | P1 4 (LCD D6) |
28 | PG3 ( TOSC2 ) | RamboDigital pin 71 | P1 3 (LCD D7) |
29 | PG4 ( TOSC1 ) | RamboDigital pin 70 | P1 5 (LCD D5) |
30 | RESET | RESET | Reset |
31 | VCC | VCC | VCC |
32 | GND | GND | GND |
33 | XTAL2 | XTAL2 | XTAL2 |
34 | XTAL1 | XTAL1 | XTAL1 |
35 | PL0 ( ICP4 ) | Digital pin 49 | X Direction |
36 | PL1 ( ICP5 ) | Digital pin 48 | Y Direction |
37 | PL2 ( T5 ) | Digital pin 47 | Z Direction |
38 | PL3 ( OC5A ) | Digital pin 46 (PWM) | XY VREF PWM |
39 | PL4 ( OC5B ) | Digital pin 45 (PWM) | Z VREF PWM |
40 | PL5 ( OC5C ) | Digital pin 44 (PWM) | E VREF PWM |
41 | PL6 | Digital pin 43 | E Direction |
42 | PL7 | Digital pin 42 | |
43 | PD0 ( SCL/INT0 ) | Digital pin 21 (SCL) | P3 6 |
44 | PD1 ( SDA/INT1 ) | Digital pin 20 (SDA) | P3 8 |
45 | PD2 ( RXDI/INT2 ) | Digital pin 19 (RX1) | J19 6 |
46 | PD3 ( TXD1/INT3 ) | Digital pin 18 (TX1) | J19 8 |
47 | PD4 ( ICP1 ) | RamboDigital pin 81 | |
48 | PD5 ( XCK1 ) | RamboDigital pin 82 | P1 7 (LCD RS) |
49 | PD6 ( T1 ) | RamboDigital pin 83 | |
50 | PD7 ( T0 ) | Digital pin 38 | |
51 | PG0 ( WR ) | Digital pin 41 | X Chipselect |
52 | PG1 ( RD ) | Digital pin 40 | |
53 | PC0 ( A8 ) | Digital pin 37 | X Step |
54 | PC1 ( A9 ) | Digital pin 36 | Y Step |
55 | PC2 ( A10 ) | Digital pin 35 | Z Step |
56 | PC3 ( A11 ) | Digital pin 34 | E0 Step |
57 | PC4 ( A12 ) | Digital pin 33 | |
58 | PC5 ( A13 ) | Digital pin 32 | SPI Flash Chipselect |
59 | PC6 ( A14 ) | Digital pin 31 | |
60 | PC7 ( A15 ) | Digital pin 30 | |
61 | VCC | VCC | VCC |
62 | GND | GND | GND |
63 | PJ0 ( RXD3/PCINT9 ) | Digital pin 15 (RX3) | P2 4 (LCD SD Detect) |
64 | PJ1 ( TXD3/PCINT10 ) | Digital pin 14 (TX3) | P2 6 (LCD BTN_EN1) |
65 | PJ2 ( XCK3/PCINT11 ) | RamboDigital pin 72 | P2 8 (LCD BTN_EN2) |
66 | PJ3 ( PCINT12 ) | RamboDigital pin 73 | J19 7 |
67 | PJ4 ( PCINT13 ) | RamboDigital pin 75 | |
68 | PJ5 ( PCINT14 ) | RamboDigital pin 76 | P3 9 |
69 | PJ6 ( PCINT 15 ) | RamboDigital pin 77 | P2 7 (SDSS) |
70 | PG2 ( ALE ) | Digital pin 39 | Y Chipselect |
71 | PA7 ( AD7 ) | Digital pin 29 | X Enable |
72 | PA6 ( AD6 ) | Digital pin 28 | Y Enable |
73 | PA5 ( AD5 ) | Digital pin 27 | Z Enable |
74 | PA4 ( AD4 ) | Digital pin 26 | E0 Enable |
75 | PA3 ( AD3 ) | Digital pin 25 | |
76 | PA2 ( AD2 ) | Digital pin 24 | |
77 | PA1 ( AD1 ) | Digital pin 23 | |
78 | PA0 ( AD0 ) | Digital pin 22 | |
79 | PJ7 | RamboDigital pin 74 | |
80 | VCC | VCC | VCC |
81 | GND | GND | GND |
82 | PK7 ( ADC15/PCINT23 ) | Analog pin 15 (69) | Y Diag |
83 | PK6 ( ADC14/PCINT22 ) | Analog pin 14 (68) | Z Diag |
84 | PK5 ( ADC13/PCINT21 ) | Analog pin 13 (67) | Z Chipselect |
85 | PK4 ( ADC12/PCINT20 ) | Analog pin 12 (66) | E Chipselect |
86 | PK3 ( ADC11/PCINT19 ) | Analog pin 11 (65) | E Diag |
87 | PK2 ( ADC10/PCINT18 ) | Analog pin 10 (64) | X Diag |
88 | PK1 ( ADC9/PCINT17 ) | Analog pin 9 (63) | |
89 | PK0 ( ADC8/PCINT16 ) | Analog pin 8 (62) | P3 10 |
90 | PF7 ( ADC7/PCINT15 ) | Analog pin 7 (61) | P1 8 (LCD Enable) |
91 | PF6 ( ADC6/PCINT14 ) | Analog pin 6 (60) | |
92 | PF5 ( ADC5/TMS ) | Analog pin 5 (59) | P1 6 (LCD D4) |
93 | PF4 ( ADC4/TMK ) | Analog pin 4 (58) | |
94 | PF3 ( ADC3 ) | Analog pin 3 (57) | Z Probe Thermistor |
95 | PF2 ( ADC2 ) | Analog pin 2 (56) | Thermistor 2 |
96 | PF1 ( ADC1 ) | Analog pin 1 (55) | Thermistor 1 |
97 | PF0 ( ADC0 ) | Analog pin 0 (54) | Thermistor 0 |
98 | AREF | Analog Reference | |
99 | GND | GND | GND |
100 | AVCC | VCC | VCC |
Digital Pin Locations
Here is a image that shows the locations of digital pins for the j19 p1 p2 and p3 pin headers.
ArduinoISP Connection Diagram
Here is a connection diagram for wiring up an arduino to be used as an AVR ISP in order to program the bootloader.
To program the standard Arduino Bootloader select:
- Tools->Board->Mega 2560
- Tools->Programme:ArduinoISP
- Tools->Burn Bootloader
These bootloaders will allow larger firmware sizes than the Arduino Mega standard one:
- https://github.com/prusa3d/stk500v2-prusa
- https://github.com/ultimachine/Arduino-stk500v2-bootloader
Example avrdude commands are documented here: Rambo_development
