Granite Host
(Redirected from Granite host)
Example Development
Release status: unknown
documenting a generic tool/artpiece
About
The Granite Host project is designed to be a gradual transition away from G Code based communications. The first initial step is to take as much processing and conversions away from the Arduino board as possible. This reduces the code size and the amount of processing the Arduino needs to do, as well as enabling on the fly changes in scaling, etc. Stage two is being developed to the extent required to fulfill the goals established in Stage one. Stage two is to make the communications protocol less dense. Stage three is to introduce new and faster mediums of communication.
Protocol
Granite Host uses Granite_Protocol_A
G Codes of various types will be supported as input for conversion.
Project Release Log
2010.11.20 - Released the version .01 draft of the GPA
Project Target Releases
2010.11 - Complete and release all proof of concept software(Parser, firmware) for GPA and documentation.
2010.12 - Unify the separate tools into a program with a serial sender. Try and figure out pseudo acceleration support for GPA.
Your-File-Name SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name CAD FILES FOR PARTS These are CAD files for each part. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name EVEN MORE FILES These are are even more files. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)|-
Your-File-Name SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
Supporting Documentation
More Examples
