Rostock_Mini_Pro Documentation
BOM
Bowden Extrusion
| Count |
Item |
| 2 |
Push-in Fitting |
Specification unknown.
| 2 |
Teflon Tubing |
Inner/outer diameter, length unknown.
| 1 |
22-Teeth Steel Gear |
Modulus, size unknown.
Linear Motion
| 1x 625ZZ Bearing
| 6x LM8UU Bearing
| 6x 608ZZ Bearing
| 12x Traxxas 5347 U-joints
| 3x GT-2 36 Pulley
| 3x GT-2 Belt (1m)
| 3x Belt Spring Tensioner
Electronics
| 3x Endstopper
| 1x RAMPS 1.4 Assembled (modified for laptop charger)
| 3x Nema 17 Motor
| 1x Nema 17 Motor coupled with Planetary Gearbox
| 1x 12V 10A Laptop Charger
Frame
| 6x 8mm Hardened Zinc-coated Precision Rod (49cm)
| 6x 3K Carbon Fiber Tubes (15cm)
| 1x Acrylic Top Plate
| 1x Acrylic Bottom Plate
| 16x Rostock Mini Pro Printed Parts
Others
| 1x J-head MKIV Hotend
| 30x 3mm Zip-ties
| Various Bolts and Nuts
