Spontaneous polymerization resin blends
Back to Printing Materials page
Spontaneous Polymerization Resin Blends
There are many dual component polymers available in the market that illustrate this behavior. Most of them are epoxys and are excellent materials as well as versatile. Some dual polymer mixes are in a 1:1 proportion or similar and could be counted in the auto-initiated sub-category of polymers. Nevertheless, for our purposes, both cases have identical applications and usage parameters.
Resins, Oligomers, Monomers
Putty, fast hardening Epoxy
Polyester Resins (Isophthalic, Vinyl Ester, Marine, General purpose, Casting Resin, Surfboard Resin, Gelcoat)
Polyester Resins and Gelcoats at uscomposites
Epoxy Resins and more at Decomp
Epoxy Resins at uscomposites
Polyester Putty and other stuff at uscomposites
Epoxy Resins (Thin coat, thick coat...)
A good website to find all types of monomers and oligomers with their descriptions and properties can be found at this very complete site:
Oligomers at Sartomer.com
Monomers at Sartomer.com
or at
BASF Resins
Catalysts Systems
Monomers, MEK-Peroxide hardener for polyesters
Benzoyl Peroxide hardner for polyesters
Fillers
Go to Fillers section
Formulation Examples
Additives
Glossary of Terms and Definitions
Here you will find a short and basic explanation of terms used in all the sections above. If some term used above seems unclear to you, please post a message in the forum and I will see to add the term to this glossary.
Go to glossary of terms and definitions
