Talk:MKS GEN
bonjour
Comment utiliser Heather 1 D7 pour E1
Merci
dans {Pins.h}
J'ai trouve par moi même, remplacer le "-1 " en "7"
#if MB(RAMPS_13_EFB) || MB(AZTEEG_X3)
   #define HEATER_1_PIN       -1
 #else
   #define HEATER_1_PIN       9    // EXTRUDER 2 (FAN On Sprinter)
 #endif
OU
#if MOTHERBOARD == 33 || MOTHERBOARD == 67
 #else
 #endif
MOTHERBOARD 33 Instructions
For the MKS Gen v 1.4 is it still MOTHERBOARD 33 which is the Ramps 1.3? It looks like the MKS boards were added to Marlin. Should it now be MOTHERBOARD BOARD_MKS_GEN_13 which is number 44 in Marlin 1.1.9 (see http://marlinfw.org/docs/development/boards.html)? The following is from the Marlin 1.1.9 sketch...
// // RAMPS 1.3 / 1.4 - ATmega1280, ATmega2560 //
define BOARD_RAMPS_OLD 3 // MEGA/RAMPS up to 1.2
#define BOARD_RAMPS_13_EFB 33 // RAMPS 1.3 (Power outputs: Hotend, Fan, Bed)
  1. define BOARD_RAMPS_13_EEB 34 // RAMPS 1.3 (Power outputs: Hotend0, Hotend1, Bed)
  2. define BOARD_RAMPS_13_EFF 35 // RAMPS 1.3 (Power outputs: Hotend, Fan0, Fan1)
  3. define BOARD_RAMPS_13_EEF 36 // RAMPS 1.3 (Power outputs: Hotend0, Hotend1, Fan)
  4. define BOARD_RAMPS_13_SF 38 // RAMPS 1.3 (Power outputs: Spindle, Controller Fan)
  1. define BOARD_RAMPS_14_EFB 43 // RAMPS 1.4 (Power outputs: Hotend, Fan, Bed)
  2. define BOARD_RAMPS_14_EEB 44 // RAMPS 1.4 (Power outputs: Hotend0, Hotend1, Bed)
  3. define BOARD_RAMPS_14_EFF 45 // RAMPS 1.4 (Power outputs: Hotend, Fan0, Fan1)
  4. define BOARD_RAMPS_14_EEF 46 // RAMPS 1.4 (Power outputs: Hotend0, Hotend1, Fan)
  5. define BOARD_RAMPS_14_SF 48 // RAMPS 1.4 (Power outputs: Spindle, Controller Fan)
  1. define BOARD_RAMPS_PLUS_EFB 143 // RAMPS Plus 3DYMY (Power outputs: Hotend, Fan, Bed)
  2. define BOARD_RAMPS_PLUS_EEB 144 // RAMPS Plus 3DYMY (Power outputs: Hotend0, Hotend1, Bed)
  3. define BOARD_RAMPS_PLUS_EFF 145 // RAMPS Plus 3DYMY (Power outputs: Hotend, Fan0, Fan1)
  4. define BOARD_RAMPS_PLUS_EEF 146 // RAMPS Plus 3DYMY (Power outputs: Hotend0, Hotend1, Fan)
  5. define BOARD_RAMPS_PLUS_SF 148 // RAMPS Plus 3DYMY (Power outputs: Spindle, Controller Fan)
// // RAMPS Derivatives - ATmega1280, ATmega2560 //
  1. define BOARD_3DRAG 77 // 3Drag Controller
  2. define BOARD_K8200 78 // Velleman K8200 Controller (derived from 3Drag Controller)
  3. define BOARD_K8400 79 // Velleman K8400 Controller (derived from 3Drag Controller)
  4. define BOARD_BAM_DICE 401 // 2PrintBeta BAM&DICE with STK drivers
  5. define BOARD_BAM_DICE_DUE 402 // 2PrintBeta BAM&DICE Due with STK drivers
  6. define BOARD_MKS_BASE 40 // MKS BASE v1.0
  7. define BOARD_MKS_BASE_15 405 // MKS v1.5 with Allegro A4982 stepper drivers
  8. define BOARD_MKS_BASE_HEROIC 41 // MKS BASE 1.0 with Heroic HR4982 stepper drivers
#define BOARD_MKS_GEN_13 47 // MKS GEN v1.3 or 1.4 Also the wording is confusing as presented. I would delete "MOTHERBOARD 34" at the end of the comments because it sounds like you are saying the MKS Gen is compatible with MOTHERBOARD 34 rather than I believe that was the default value left at the end of the comment.
