User talk:Ckaos
Welcome
Dear Ckaos,
Welcome to RepRap!
The Doboz looks very clean and professional. Congratulations on getting it running. Thank you for showing it to us.
I'm happy to learn that I can build a perfectly functional RepStrap without all the of heavy, thick, difficult-to-cut metal used in the ORE-Bot or most Extruded Aluminum RepStraps :-). --DavidCary 22:38, 14 November 2010 (UTC)
Hello David ! Thanks a lot for the warm Welcome! Yes those L shaped aluminum profiles are really (relatively) easy to work with , and to obtain :) I will update the wiki about that aspect of the build process as soon as i have time.
Thanks again, and if you have any thoughts on improvements, don't hesitate :) Mark
Hi Ckaos,
I just noticed Doboz-Web. It'd be great if you considered using Libreprap in a future version. It's designed to abstract away as much of the communications difficulties as possible - improving compatibility with all the various (slightly incompatible in ridiculous ways) firmwares out there. It also leaves us only one place to make changes to host software when someone develops a new communications protocol.
You can find example code for using libreprap in gcdump, and repsnapper, and the developer(s) are usually available in #repsnapper on freenode.
Thanks for your work! --Timschmidt
