Item |
Quantity |
Notes
2020 Aluminum extrusion, 500mm |
2 |
One 4000mm piece of extrusion from Misumi covers everything with a *little* extra.
2020 Aluminum extrusion, 400mm |
4
2020 Aluminum extrusion, 330mm |
3
M10 Smooth Rod, 500mm |
2
M10 Smooth Rod, 370mm |
2
M10 Smooth Rod, 320mm |
2
8mm lead screw, 300mm |
2
GT2 timing belt, w=6mm |
2 meters
GT2 pulley |
2
M5 x 10mm machine screw |
55
M5 t slot nut |
55
M4 x 10mm machine screw |
4 |
These are used for the psu mounting bracket
M4 x 20mm machine screw |
4 |
For belt idlers and tensioners
M4 x 25mm machine screw |
4 |
These are used to mount the extruder to the X carriage
M4 hex nut |
6
M4 lock nut |
2 |
Use for idler bearing assemblies
M3 x 10mm machine screw |
12 |
Z and Y axis motor mounts
M3 x 14mm machine screw |
19 |
3 for X motor, 4 for extruder fan, 2 for lcd mount, 4 for lead screw nut mounts, 2 for ramps cooling fan, for for y table
M3 x 25mm machine screw |
6 |
3 for extruder stepper motor, 1 for fan duct to the extruder, 2 for tensioners
M3 x 30mm machine screw |
6 |
4 for print bed, 2 for hot end clamp / servo mount
M3 x 60mm machine screw |
2 |
These are used for the extruder
M3 hex nut |
22
M3 lock nut |
5 |
use locknuts for print bed mount and fan duct mount
M3 washer |
10 |
Need 4 for extruder springs, but have some handy if needed elsewhere
M2 x 16mm machine screw |
9 |
These and M2 nuts for mounting end stops, 1 for servo mount, and 2 for LM2596 mount
M2 hex nut |
9
Piece |
Quantity needed |
Model file
X end idler |
1 |
X-end-idler.stl
X end motor |
1 |
X-end-motor.stl
X carriage |
1 |
X-carriage.stl
X belt tensioner |
1 |
X-tensioner.stl
Y end idler |
1 |
Y-idler.stl
Y belt tensioner |
1 |
Y-tensioner.stl
Y end motor |
1 |
Y-motor.stl
Y table mount |
1 |
Y-table-10.stl
Z motor holder, left |
1 |
Z-motor-left.stl
Z motor holder, right |
1 |
Z-motor-right.stl
Z top frame, left |
1 |
Z-top-left.stl
Z top frame, right |
1 |
Z-top-right.stl
Z lower corner brace, front/right, back/left |
2 |
Z-lower-brace-1.stl
Z lower corner brace, front/left, back/right |
2 |
Z-lower-brace-2.stl
Y frame brace |
4 |
Y-brace.stl
Idler bearing guide (two parts makes one guide) |
4 |
Belt-guide-624.stl
Extruder body / idler / hot end clamp set |
1 |
Extruder-direct-drive.stl
Servo mount |
1 |
servo_mount.stl
Servo endstop mount |
1 |
Servo-endstop-holder.stl
Extruder fan duct |
1 |
Fanduct-e3dlite6.stl
Electronics frame mount (for RAMPS) |
1 |
Ramps-mount.stl
Filament spool support (two pieces) |
1 |
Filament-mount.stl
SMART display frame mount (one piece) |
1 |
Smartlcd-mount.stl
12V PSU frame mounting bracket |
2 |
Psu-mount.stl
Power switch mount |
1 |
Power-switch-mount.stl
Item |
Quantity |
Notes
NEMA17 Stepper motor |
5 |
4-wire bipolar, high torque preferrably
MDF board (heated bed mount) |
1 |
see drawing for board in doc/
Heat bed PCB |
1 |
200x300mm MK1
Heat bed thermistor |
1
Glass bed |
1 |
3mm borosilicate or picture frame glass
Controller (Mega/RAMPS, Rambo, etc) |
1 |
Arduino Mega 2560 + RAMPS + A4988 drivers * 4
SMART lcd controller / SD reader |
1
Endstop (limit) switch |
3 |
6mm x 10mm x 20mm, “snap action” levered switch
Micro servo (9g type) |
1 |
add wire to make ~ 70cm
LM10UU linear bearing |
12
608ZZ roller bearing |
2 |
these go in the z tops to hold the upper end of the lead screws (ok if you don't have them)
624RS roller bearing |
3 |
one for each belt idler, one for extruder
MK7 Drive gear (or similar) |
1
Brass or delrin lead screw nut |
2 |
Probably comes with your lead screws?
5mm to 8mm flexible shaft couplers |
2 |
aluminum
40mm x 40mm x 10mm fan |
1 |
12V
80mm x 80mm x 10mm fan |
1 |
For use with RAMPS frame mount
Miniature zip ties |
20 |
This number is approximate
Extruder idler springs |
2 |
High tension, 1” unsprung length, >3mm ID
Bed leveling springs |
4 |
Lower tension is OK, 1” unsprung, ID > 3mm
Power Supply |
1 |
Size appropriately for heat bed and extruder
Hot end |
1 |
E3d lite6 or E3d v6
Power switch |
1 |
KCD1-104N (12mm x 19mm body)
