Adapto
Revision as of 13:20, 12 January 2013 by ROTORIT (talk | contribs)
Adapto
Adapto is a 3D printer that can be built with many different types of frames and frame materials.
GPL
The ADAPTO!!
The thought behind the Adapto 3D printer is that one can use the same printed parts on printers with different types of materials (in the frame).
The history behind this design is that i got hold of some alu extrusions that was intended to be used on a MendelMax. During the MM build i got so extremely annoyed with how over engineered it is so I decided to tear the MM apart in favor to make a design that only used 50% of the MM extrusions (that means i now have enough extrusions for 2 printers :D ).
I also designed the parts in a way that makes the builder able to use either Alu extrusions (20x20mm), wood, alu, acryl plates or plates made out of any material actually (if it is stiff enough).
I recommend not using anything thicker than 20mm thick plates/stripes (due to the y motor mount and y idler parts) and use max 34mm wide frame parts (due to the design of the feets), but thinner is ok if the material is stiff enough.
More information
This is also posted on:
The most up to date Files will always be on GitHub.
ENJOY!
This is such an easy build it dont need much instructions.
  • Print the parts
  • choose your frame material
  • look at the pictures
  • BUILD IT! :D
Thanks to the entire RepRap- and Thingiverse- comunity for all the inspiration.
All the pictures can be viewed and downloaded from Thingiverse and GitHub
The Wooden frame is just an example of what you CAN use for frame material. Open your mind and let the creativity flow! :D
If you decide to build one, please feel free to add a pin on the Adapto map.
_________________________________________________________________________________________________________________________________
RP parts
This is the RP parts you need to build a 20x20mm alu extrusion framed Adapto with 8mm smooth rods, M5 Z-threaded rods and makes a 200x240mm build area with a Z travel up to about 270mm
So if you have a MendelMax frame laying around you can build 2 of this Adapto 3D printer :-)
This table is still under construction and is not yet complete.
Quantity Part Name Part Type Used Where Comment Looks like File Download
4 Y_Rod_Clamp_4_Off.stl RP Frame Holds the Y smooth rods firmly to the frame. You need 4 of these for each Adapto printer you build Adapto y rod clamp 8mm.jpg [1]GitHub,
[2]Direct
1 Y_Motor_Mount_1_Off.stl RP Frame Holds the Y motor to the frame. Fits a Nema 17 stepper motor just fine. You need 1 of this for each Adapto printer you build Adapto Y motor mount.jpg [3]GitHub,
[4]Direct
1 Y_Idler_1_Off.stl RP Frame This is the Y axes belt idler that holds the Y belt idler bearing(s) firmly to the frame. You need to print 1 of this .stl file (that actually contains 2 plastic parts) for each Adapto printer you build. Adapto y idler.jpg [5]GitHub,
[6]Direct
1 Y_Belt_Block_1_Off.stl RP Bed This part is to be mounted under the bed. It holds both ends of the Y belt firmly to the bed making the stepper able to move the Y akses. The belt can for example be mounted to this wit Zipties and make you able to get the belt nice and tight. You need one of this for each Adapto printer you build. Adapto Y belt block.jpg [7]GitHub,
[8]Direct
3 Y_Bearing_Holder_LM8UU_3_Off.stl RP Bed Holds the Y axes bearings that slide on the Y smooth rods. Is to be mounted under the bed and holds a firm grasp on the y linear bearings of choice as long as the bearings have a outer diameter of about 15mm. You need at least 3 of these on each Adapto Printer you build. Some people prefer to use 4. Adapto y bearing holder.jpg [9]GitHub,
[10]Direct
2 Z_Motor_Holder_2_Off.stl RP Frame Holds the Z motors firmly to the frame. You need 2 of this for each Adapto you build. Adapto z motor mounts.jpg [11]GitHub,
[12]Direct
1 Z_Couplers_M5.stl RP Z Motors Couples the Z threaded rods firmly to the Z motors. You need to print 1 of this .stl file (that actually contains 2 plastic parts) for each Adapto printer you build. Adapto z couplers M5.jpg [13]GitHub,
[14]Direct
1 (o)(o)
1 (o)(o)
