Adapto
Revision as of 16:47, 18 May 2013 by ROTORIT (talk | contribs) (Build step 1: Frame assembly.)
Adapto
Adapto is a 3D printer that can be built with many different types of frames and frame materials.
GPL
ADAPTO
Screenshot of the .blend file
Info
The thought behind the Adapto 3D printer is that one can use the same printed parts on printers with different types of materials (in the frame).
The history behind this design is that i got hold of some alu extrusions that was intended to be used on a MendelMax. During the MM build i got so extremely annoyed with how over engineered it is so I decided to tear the MM apart in favor to make a design that only used 50% of the MM extrusions (that means i now have enough extrusions for 2 printers :D ).
I also designed the parts in a way that makes the builder able to use either Alu extrusions (20x20mm), wood, alu, acryl plates or plates made out of any material actually (if it is stiff enough).
I recommend not using anything thicker than 20mm thick plates/stripes (due to the y motor mount and y idler parts) and use max 34mm wide frame parts (due to the design of the feets), but thinner is ok if the material is stiff enough.
For an alu Adapto Walkaround Video, see http://www.youtube.com/watch?v=RWmtuGsg8Us
Some variants
Aluminum Adapto
A wooden adapto
As known this is a VERY "hackable" design and have a lot of options. It is impossible to cover all the things one can do to make the Adapto printer design work but if you are interested you can read about some more options and things that is possible on the Sample BOM for a Big T-Slot Adapto page. That BOM page lists parts, gives sample sources, and discusses possible alternatives.
ChristianS have made a awesome job making that page and it is highly recommended to pop by to read it.
Open your mind and let the creativity flow!
More info
This is also posted on:
The most up to date Files will always be on GitHub.
This is such an easy build it dont need much instructions.
  • Print the parts
  • choose your frame material
  • look at the pictures
  • BUILD IT! :D
Thanks to the entire RepRap- and Thingiverse- comunity for all the inspiration.
All the pictures can be viewed and downloaded from Thingiverse and GitHub
If you decide to build one, please feel free to add a pin on the Adapto map.
ENJOY!
Parts
Although this is a easy to build printer one need some parts for it.
  • RP parts that is the Printet plastic parts like extruder, smooth rod holders and parts that holds the frame together.
  • Frame that in this case is 20x20mm aluminum t-slot extrusions.
  • Smooth rods that in this case is 8mm thick.
  • Vitamins like screws, nuts, bearings, hobbed bolt, belts, pulleys springs and more.
  • Electronics that controls and drive the unit and also things like stepper motors, PSU, thermistors, heated bed, hot end, wires and more.
RP parts
This is the RP parts you need to build a 20x20mm alu extrusion framed Adapto with 8mm smooth rods, M5 Z-threaded rods and makes a 200x240mm build area with a Z travel up to about 270mm
So if you have a MendelMax frame laying around you can build 2 of this Adapto 3D printer :-)
Quantity Part Name Part Type Used Where Comment Looks like File Download
4
Y_Rod_Clamp_4_Off.stl
RP
Y rod clamps
Holds the Y smooth rods firmly to the frame. You need 4 of these for each Adapto printer you build.
For printing this part, recommended is 35% infill, 2 top/bottom/perimeter layers or more.
Y rod clamps
[1]GitHub,
[2]Direct
1
Y_Motor_Mount_1_Off.stl
RP
Y motor mount
Holds the Y motor to the frame. Fits a Nema 17 stepper motor just fine. You need 1 of this for each Adapto printer you build.
Y motor mount
[3]GitHub,
[4]Direct
1
Y_Idler_1_Off.stl
RP
Y idler
This is the Y axes belt idler that holds the Y belt idler bearing(s) firmly to the frame. You need to print 1 of this .stl file (that actually contains 2 plastic parts) for each Adapto printer you build.
Y idler
[5]GitHub,
[6]Direct
1
Y_Belt_Block_1_Off.stl
RP
Y belt block
This part is to be mounted under the bed. It holds both ends of the Y belt firmly to the bed making the stepper able to move the Y akses. The belt can for example be mounted to this with Zipties and make you able to get the belt nice and tight. You need one of this for each Adapto printer you build.
Y belt block
[7]GitHub,
[8]Direct
3
Y_Bearing_Holder_LM8UU_3_Off.stl
RP
Y bearing holders
Holds the Y axes bearings that slide on the Y smooth rods. Is to be mounted under the bed and holds a firm grasp on the y linear bearings of choice as long as the bearings have a outer diameter of about 15mm. You need at least 3 of these on each Adapto printer you build. Some people prefer to use 4.
Y bearing holders
[9]GitHub,
[10]Direct
2
Z_Motor_Holder_2_Off.stl
RP
Z motor holder
Holds the Z motors firmly to the frame. You need 2 of this for each Adapto you build.
Z motor holder
[11]GitHub,
[12]Direct
1
Z_Couplers_M5.stl
RP
Z couplers
Couples the Z threaded rods firmly to the Z motors. You need to print 1 of this .stl file (that actually contains 2 plastic parts) for each Adapto printer you build.
Z couplers
[13]GitHub,
[14]Direct
4
Foot_4_Off.stl
RP
Feet
Holds the lower frame firmly assembled and also work as the feet clearing the Z motors from the table keeping the nice look intact. You need 4 of these for each Adapto printer you build.
Feet
[15]GitHub,
[16]Direct
2-10
90_innerCorner.stl
RP
90 inner corner
Primary to support the frame on the opposite side of the extrusion from the Z_Smooth_Rod_Holder_Lower_2_Off.stl helps to keep the high frame at 90 degrees onto the lower frame. Recommended is to also use 4 more supporting the high frame in x direction. Some people also prefer to use even 4 more of these on the inside corner on the back side of the feet. Optional buy some metal corners to do the job if you like overkill and don't trust your mother.
90 inner corner
[17]GitHub,
[18]Direct
1
Extruder_Idler_1_Off.stl
RP
Extruder idler
Holds the extruder idler that squeeze the filament up against the hobbed bolt for consistent plastic feeding. Holds a 608 bearing with a short M8 threaded rot or preferably a sjort 8mm smooth rod. You need 1 of this for each Adapto Printer you build.
For printing this part, recommended is 60% infill, 2 top/bottom/perimeter layers or more.
Extruder idler
[19]GitHub,
[20]Direct
1
Large_Gear_T36_1_Off.stl
RP
Extruder large gear
Turns the hobbed bolt for filament feeding. It have 36 tooths and fits a M8 hobbed bolt nicely and have room for a M8 captive nut allowing it to lock on to the hobbed bolt using an additional nut. You need 1 of this for each Adapto printer you build.
Extruder large gear
[21]GitHub,
[22]Direct
1
Small_Gear_T13_1_Off.stl
RP
Extruder small gear
Sits on the extruder motor and turns the large gear. Locks to the motor axle with a M3 captive nut with M3 screw. You need 1 of this for each Adapto printer you build.
Extruder small gear
[23]GitHub,
[24]Direct
1
Extruder_X_Carriage_Combo_1_Off.stl
RP
Extruder carriage
This is both the X-carriage and extruder combined in one plastic part. It holds the weight of the nema17 close to the X-smooth rods to prevent shaking and holds the 3 linear bearings making the x akses slide smoothly. You need 1 of this for each Adapto printer you build.
Extruder carriage
[25]GitHub,
[26]Direct
2
RP
Z smooth rod holder lower
To hold the lower end of the Z smooth rod firmly to the frame. It fits a 8mm smooth rod nicely and ads another good looking part to the design. You need 2 of these for each Adapto printer you build.
[27]GitHub,
[28]Direct
2
Z_Smooth_Rod_Holder_Upper_2_Off.stl
RP
Z smooth rod holder upper
To hold the upper end of the Z smooth rod firmly to the frame. It fits a 8mm smooth rod nicely and ads another good looking part to the design. You need 2 of these for each Adapto printer you build.
[29]GitHub,
[30]Direct
1
X_End_Idler_1_Off.stl
RP
X end idler
Holds the X smooth rods, Z threaded rods firmly to the frame, the Z linear bearings in place and X idler in position to make the best possible print results. You need 1 of this for each Adapto Printer you build.
X end idler
[31]GitHub,
[32]Direct
1
X_End_Motor_1_Off.stl
RP
X end motor
Holds the X smooth rods, Z threaded rods firmly to the frame, the Z linear bearings in place and X motor in position to make the best possible print results. You need 1 of this for each Adapto printer you build.
X end motor
[33]GitHub,
[34]Direct
1
Endstop_Holders_X_3.stl
RP
Endstop holders
Holds the end stops firmly to the frame. Some changes may be expected in these soonish but will do for now. you need to print 1 of this STL (that actually contains 3 plastic parts) for each Adapto printer you build.
Endstop holders
[35]GitHub,
[36]Direct
Frame
Quantity Length Part Type Used Where Comment Looks like
2 300mm 20x20mm aluminum extrusion
2x300mm
This is the frame parts that determine the width of the frame.(X direction) Using 300mm extrusions here will result in about 250mm X-travel.
In other words, about 50mm loss of X-travel relative to these frame parts. (If you need for example 300mm X-travel you have to use 350mm extrusions here.)
You need 2 of these 300mm lengths for each Adapto printer you build.
Alu extrusions
2 340mm 20x20mm aluminum extrusion
2x340mm
This is the frame parts that determine the length of the frame.(Y direction) Using 340mm extrusions here will result in about 210mm Y-travel.
In other words, about 130mm loss of Y-travel relative to these frame parts. (If you need for example 300mm Y-travel you have to use 430mm extrusions here.)
You need 2 of these 340mm lengths for each Adapto printer you build.
Alu extrusions
3 420mm 20x20mm aluminum extrusion
3x420mm
This is the frame parts that determine the Height of the frame.(Z direction) Using 420mm extrusions here will result in about 270mm Z-travel.
In other words, about 150mm loss of Z-travel relative to these frame parts. (If you need for example 300mm Z-travel you have to use 450mm extrusions here.)
You need 3 of these 420mm lengths for each Adapto printer you build.
Alu extrusions
Smooth rods
Part Used Where Quantity Recommended minimum lengths. Comment Looks like
X-smooth rods
X smooth rods
2 400mm Can without problems be longer than recommended minimum lengths.
Smooth rods
Y-smooth rods
Smooth rods
2 380mm Can without problems be longer than recommended minimum lengths.
Y smooth rods
Z-smooth rods
Smooth rods
2 440mm Can without problems be longer than recommended minimum lengths.
Z smooth rods
Vitamins
work in progress..... Some more awesomeness coming soon here :-)
Electronics
How to build
Under construction ;-)
This guide is JUST A GUIDE and you don't have to follow this to the point. It is made to give you a good idea of how to do it and is not meant to be a ultimate blueprint of how to build the Adapto Printer. There might be a chance that you don't have the exact same parts as in this guide. The nuts might be slightly different, maybe you use thicker smooth rods and have the 10mm parts from the Adapto GitHub or maybe even use another frame material and color. There might be some upgrades that haven't been picked up and implemented in the guide just yet so please use it as a GUIDE, nothing else :-)
Anyway.. HERE WE GO! :D
Vitamins needed in this step
  • All Aluminum extrusions. 3x 420mm, 2x 340mm and 2x 300mm 7 lengths total
  • 88x T-slot nuts.
  • 47x M5x10mm screws.
  • 46x M5x12mm screws
  • 81x M5 washers (or 89 if you want to use washers on the Y-smooth rod holders).
  • 1x M8x40mm bolt (or some M8 threaded rod).
  • 4x M8 washers.
  • 2x M8 Nuts (+ 2, M8 lock nuts if you fancy that)
  • 2x 608 bearings.
RP-parts needed in this step
  • The 4 feet.
  • 10 corner brackets.
  • The 2 Y-idler parts.
  • The Y-motor mount.
  • The 2x Z-smooth rod holder opper parts.
  • The 2x Z-smooth rod holders lower parts.
  • The 4x Y-smooth rod holders.
  • The 2 Z-motor holders.
Mounted as shown in the pictures
1. EParts view
2. Tools you may need.
3. Clean the parts if necessary.
4. Make sure the holes is big enough to fit your Vitamins.
Some drilling might be needed.
5. Start by insering 2 T-slot nuts into one of the 340 extrusions
and mount one of the corner brackets with 2x M5x10mm screws with washers like this.
6. Insert 2 T-slot nuts into one of the 300mm extrusions and screw
it onto the first 340mm extrusion with 2 more M5x10mm screws w/washers like this.
7. Insert 3 nuts into the inner slot of the 300mm Extrusion and add
a corner bracket like this. The 3rd nut is for the Y motor mount and can not be added later on.
8. Insert 2x T-slot nuts into the orher 340mm extrusion
and mount it like this.
9. Insert 2 T-slot nuts into the inner slot of the 340mm extrusion and add
Another corner bracket like this.
10. Do the same on the other (side) 340mm extrusion.
Simple as that :-)
Still in progress!
