Bearing
Revision as of 12:37, 4 April 2013 by FDBI-Paris (talk | contribs) (Linear Ball Bearings)
Ball Bearings
Cheap and widely available
The first digit refer to the kind of bearing, the second its robustness, the third usually for the bore size. Then ZZ = double shielded ; 2RS = double sealed ; etc.
If we were generating a lot of dust and grit -- perhaps with a Milling and Drilling Head -- we would want two rubber seals ("2RS") to keep the dust and grit out. But most RepRaps are *not* generating a lot of dust and grit, so we usually prefer metal shields ("ZZ") or unshielded (??) in order to make it easier to add a little lubrication oil.
Learn more here : http://www.gizmology.net/bearings.htm
For the most common size :
  • 623 = 3 x 10 x 4mm (ID-OD-thick)
  • 624 = 4 x 13 x 5mm
  • 626 = 6 x 19 x 6mm
  • 608 = 8 x 22 x 7mm
Supplier From Model Approximate Cost Additional notes
Charlie's 3D Technologies Belgium 608zz 0,61 € -
Paoparts France 623zz, 624zz, 626zz, 608zz 0,69 - 1,20 € -
Reprapsource Germany 624zz, 608zz 0,69 - 0,79 € -
Reprapkit UK 624zz, 608zz, 6810zz 0,85 - 0,95 £ -
Bocabearings US many - -
VXB US many - -
DDB-Tech China many - -
Technobots Uk many - -
CIE Auto Source China many - -
3dprinterfactory Australia 608zz $2.20 AU ea -
wholesale skateboard US 608ss $ 0.38-0.50 ea minimum 80 pcs
imprimante3DFrance France 608ZZ, 624ZZ - Paris area
The "608" size ball bearings in particular are extremely low cost. Their 8 mm bore size almost forces us to mount them on:
The "626" size ball bearing have a 6 mm bore size. We can mount them on
The "624" bearing have a 4 mm bore size. We can mount them on
(The 626 and 624 bearings seem to cost more than 608 bearings, but M6 and M4 bolts and threaded bar cost less than M8 threaded bar and bolts, so it's almost a wash).
A little costlier than classical bearings, but simpler to integrate in carriage design and make building a machine quicker/easier. Worth the cost.
Model From Size (ID-OD-long) Approximate Cost Additional notes
LM8UU Charlie's 3D Technologies Belgium 8 x 15 x 24 mm 1,75 € -
LM6UU Paoparts France 6 x 12 x 19 mm 2,90 € -
LM8UU Paoparts France 8 x 15 x 24 mm 1,95 € -
LM8UU fabberworld Switzerland 8 x 15 x 24 mm 1,95 € -
LME8UU Reprapsource Germany 8 x 16 x 25 mm 6,99 € pack of 2
LME8LUU Reprapsource Germany  ? 3,99 € -
LM10UU Paoparts France 10 x 19 x 29 mm 2,95 € -
LM10UU fabberworld Switzerland 10 x 19 x 29 mm 3,05 € -
SCS8UU Paoparts France 8 x 35 x 30 mm 14,50 € with 4 M3 holes, sold in pair
3dprinterfactory Australia LM8UU $2.80 AU ea- -
imprimante3DFrance France LM8UU 3,85€ for 2 pieces Paris area
Bushing
Less noisy than linear ball bearing but not always practical to integrate
DIY PLA bushings
DIY UHMWPE linear bearings (ultra high molecular weight polyethylene) are self-lubricating, so rails can stay clean and dry.
Supplier From Size Material Approximate Cost Additional notes
Goldmine US 8 mm bronze 1 $ don't use on 5/16" rod
iglidur D6 Paoparts France 6 mm plastic 1,20 € -
iglidur D8 Paoparts France 8 x 9 x 12 mm plastic 1,50 € -
Everything Igus multiple - - -
Sdp-Si US 8 mm plastic 1,80 $ self-aligning
Spyraflow US 8 mm bronze  ? self-aligning
Techpaladin US 8 mm bronze 1,70 $ self-aligning
Linear Rail
  • Igus
  • schneeberger.com
  • pbclinear.com (also for many linear bearings)
  • Hiwin (look on ebay)
