BrickRap
Release status: Experimental
Description | A back to the roots RepRap approach
License | GPL ?
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Project Description
This is my entry for the Gada Prize.
A RepRap which is "back to the roots", in other words: Focus is not on printing speed or fancy features but on the capability to reproduce itself.
This shall be achieved by using "RepBricks" which are easily stacked together like the famous bricks for children. Compatibility to commercial brick systems will even allow to build a BrickStrap using your childrens bricks.
Inspiration for this Project Comes from the following projects: Lego_RepStrap MendeLego LEGObot 3D Printer by matstermind and LegoStrap(which is quite empty...)
However I decided to use double sized bricks to lower the part count and increase ease of assembly. NOTE: Changed to BitBeam like Bricks due to problems with Duplo like bricks
Development Goals:
- Extremely low cost
- Ultra-low vitamin count
- Brick based construction (modular concept)
- Compatibility of the bricks to commercial brick systems
- Easy to build
- Mother-Child principle:
- BrickRap children have small printing area (just enough to print parts for growing)
- Capability to grow in size by printing "growth parts"
- Rack and pinion drivetrain will make growing easier
- Herringbone gears will drive the Rack and thereby self-center the drivetrain (likely to be abandoned, printing herringbone is quite unstable on my printer)
Why use RepBricks?
While all the new developments are really great projects, they tend to be more and more professional. Costly vitamins are required for most of them. In my personal opinion the idea of a self replicating machine is not the focus of those high sophisticated machines. By using only a limited set of easily stackable "RepBricks" one could use parts from older designs for new machines (Maybe not only RepRaps). Furthermore the compatibility to commercial bricks can lower the entry barrier for beginners, as a lot of people already own enough bricks to at least build the structural parts of BrickRap.
One limiting factor in the RepRap growth function is the manual assembly. Using the Brick principle it is already possible to build assembly devices which could be used in the replication. Lego 3D-Drucker (german)
RepBricks (old version) deviate from classic Duplo-Bricks in a way that their shape is optimized for printing. This shall be achieved by replacing the "inner nibbles" by a quadratic grid of straight walls which are rotated 45° related to the outer brick walls.
RepBricks in their actual specification are strongly based on BitBeam, with some minor modification to work with pin connectors.
One more advantage which I recognized during the ongoing development process is that it is very easy to change the printer configuration when using RepBricks. This facilitates the implementation of new ideas.
Mother+Child principle
The Mother in this context is a full size BrickRap with a printing area sufficiently big to print all used RepBricks. The child however is the smallest possible BrickRap, with a print area as small as one standard (to be defined) "GrowthBrick". Using this principle a BabyBrickRap can produce the parts required for its growth on its own. In the meanwhile the MotherRap can produce more babies or help the BabyBrickRap to grow.
Preliminary BabyBrickRap specifications:
- Print area: 2x2 nibble brick
- Print height: half standard brick height (with nibbles or herringbone teeth)
Cost Reduction
One of the most important design goals for BrickRap is cost reduction. One example to achieve this is the rack and pinion carriage system for the printing plate. However with my current design there is a major drawback as the moving mass is increased by the fact that both (X and Y) motors are moving as the printing surface does. To overcome this I tried to use low weight cheap stepper motors. 28BJY-48 with a ULN2003 "driver". Connection to Ramps 1.4 was carried out using the free Pins at AUX4 and I managed to make the motor move using some modification of Repetier Firmware. However I am stuck there with some doubts how to redirect the signals from the dir/step protocol used with pollulu to the direct drive of the motor. As I completely fail in coding firmware this development is likely to be abandoned and I will go back to using Pollulu.
This is selected as major development goal, because I spent a lot of time ordering the vitamins for my WolfStrap-build. Burning two pollulus and waiting for new ones is also no nice experience.
Last but not least: Vitamin supply is costly and therefore counteracts cost reduction.
How to achieve this goal: - All structural parts are basic RepBricks - Drivetrain for X and Y movement is made of brick compatible Racks and Gears that fit directly to the Motor shaft - Z-Axis movement (Option 1): Printable screw-gear-system - Z-Axis movement (Option 2): Printable block and tackle System (fishing line as vitamin)
- Alternative electronics??? Cheap stepper motors?
Preliminary vitamin needs: stepper motors, electronics, endstops, wiring, HotEnd, Extruder-Hardware, Fan, (fishing line), screws and nuts for fixation of gears
Development Status:
a Picture of a model made of commercial bricks will follow soon.
This is the first model of BrickRap: The frame is quite stable this way. The extruder shall fit into the hole on the upside and be moveable only in Z-direction (right now I have one "Wades Extruder" which nearly fits into the model, however work has to be done to reduce its size). Therefore the printing table has to have 2 degrees of freedom. The racks are indicated by the pink bricks. The motor mounts are indicated by the orange bricks. The motors will have the herringbone gears directly on their shafts. (I hope printing resolution will anyway be not too bad. Something in the 0.5 mm range would be fine for my purposes)
For the rack and pinion drive I imagine something like Rack and Pinion for X-Axis by theodleif
ToDo [06-09-2013]
- Wait for the last missing Pollulu for my WolfStrap to finally start printing.
- Create .stl for rack and pinion System which can directly be stacked on Standard double size brick.
- Create .stl for print optimized Brick (round Pins in the inside middle will be replaced by straight crossing lines)
[14-10-2013] MAYOR PROJECT CHANGE:
WolfStrap is running.
Experimenting with Duplo-like bricks showed some problems. Stability of the links is highly depending on printer settings. Furthermore, printing time is too high with such big bricks. Changing the type of bricks seems to be necessary. Some search led me to GridBeam on Thingiverse which is highly compatible to Lego-Technic bricks.
Printing those is faster and gives more consistent results. I therefore decided to change the Brick Type to GridBeam-like bricks. Some minor changes allowed for faster printing and increased compatibility to commercial connectors.
An experimental frame was succesfully built using mainly printed parts.
I hope to upload some photos soon. I have to increase my efforts on documentation ;-) and will do so, when some of my other projects allow me to do so.
[18-10-2013]
I finally managed to take some pictures:
This is the first version of BrickRap's X-Axis carriage. I used heavy paper as a platform for trials. Driving this by wire/string works quite OK, but sidewards stability is very low. Also the required vitamins are too much (some screws, nuts, ball bearings). I quit this design.
[20-10-2013]
V2 is the first working X-Axis carriage. Rack and gear are printed. The gear directly fits on the stepper motor shaft, however I am planning to include fixation. Running the 28BJY-48 stepper motor on the pollulu is quite slow. Maybe I have to increase gear size to increase printing speed.
I had some problems getting the stepper motors running. Rewiring the plug solved the problem. Now I drive the stepper using the Ramps/Pollulu combination. Here are the cable colors: plug-motor: yel-yel; blu-pin; or-blu; pin-or. The red cable is not used. Firmware settings for printer speed have to be VERY low. Fast changes of direction lead to losses of steps. Low acceleration seems to solve this, however I am not yet confident with these motors.
[22-10-2013]
This is the complete XY-carriage. Only one motor installed so far. The bed slides on tie wire (gardening wire), but the second axis movement is not as good as the top axis movement. I will have to remove the wire and replace it by something more rigid. Vitamins used: some (black) Lego Technic Pins, tie wire, 2 screws to fix the motor and the motor itself. The wire will hopefully be replaced soon.
[23-10-2013]
The wire is now replaced by printed slide bearings. Works quite OK, still a little bit of sidewards wobbling. I will have to work on the sliders. I also increased the free space for the gear in order to replace it with a bigger one.
