CAM Toolchains
This page is a stub, you can help RepRap by expanding it
A RepRap CAM toolchain consists of all the software elements needed to create printed 3d models from CAD models to firmware.
Here we lists the various toolchain components available and provides a comparison of their features, compatible toolchain components and how to get them.
It should be noted that a comparison of CAD modeling programs is outside of the scope of this article however it should be noted that in general CAM toolchains are CAD program agnostic because they can accept standard STL models as input which almost all CAD programs can export directly or through plugins.
Firmware
Firmware | Author(s) | Compatible electronics | Compatible software drivers | dc motor extruder? | stepper extruder? | extruder speed control? | movement speed control? | thermocouples? | heated build platforms? | Installation instructions | Download |
RepRap FiveD GCode Interpreter | RepRap.org | Gen 3 (more?) | RepRap Software | ? | true | true | true | ? | ? | installation | download |
MakerBot Firmware Fork | MakerBot.com | Gen 3 (more?) | ReplicatorG | true | ? | ? | ? | true | true | installation | stable/dev |
RepRap Drivers
Driver | Author(s) | Compatible firmware(s) | Manual movement? | Manual extruder control? | Manual stepper disable? | Manual heated build platform control? | Live GCode terminal? | SD card upload? | GCode input? | Step-NC input? | Integrated GCode compiler? | Installation instructions | User manual | Download |
RepRap Host Software | RepRap.org | RepRap FiveD GCode Interpreter | true | true | false | false | false | ? | true | false | true | installation | manual | dev |
RepSnapper | Kulitorum | RepRap FiveD GCode Interpreter | ? | ? | ? | ? | false | ? | true | false | true | installation | manual | windows (stable) linux (dev) |
Note: some drivers such as the RepRap Host Software are listed here and under GCode compilers as they serve both purposes.
GCode, Etc. Compilers
Driver | Author(s) | Compatible driver(s) | Compatible firmware features | STL input? | Multiple STL input? | Step-NC input? | RFO input? | GCode output? | Step-NC output? | RFO output? | Compilation Speed | Installation instructions | User manual | Download |
RepRap Host Software | RepRap.org | RepRap FiveD GCode Interpreter | ? | true | ? | false | false | true | false | ? | ? | installation | manual | dev |
RepSnapper | Kulitorum | RepRap FiveD GCode Interpreter | ? | true | true | false | true | true | false | true | fast | installation | manual | windows (stable) linux (dev) |
