File:Layout Heatbed MK2a.svg
Revision as of 16:48, 25 June 2013 by RobertKuhlmann (talk | contribs) (I've drawn the MK2a heatbed as an SVG-file (Inkscape), so anyone can create their own heatbed with the toner transfer method, without the need to use a PCB-layout-software. Most regular Laserprinters don't support a printing range of 214mm x 214mm. You c)
Original file(SVG file, nominally 758 × 758 pixels, file size: 248 KB)
Most regular Laserprinters don't support a printing range of 214mm x 214mm. You can print the image twice in landscape format (on catalog paper), one version upside down, cut both prints at the exact half of the layout and glue them on a new sheet, big enough to cover the hole layout.
After ironing the print on the copper and removing the paper (just lay it in water and wait), check the result for breaches in the layout and fix them with laquer (etch resistant).
You can use 0.2mm board material (with 35µm copper of course) and glue it under an aluminum plate (e.g. 3mm) with thermal adhesive. This makes a very planar and lightweight heatbed.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current16:48, 25 June 2013Thumbnail for version as of 16:48, 25 June 2013758 × 758 (248 KB)RobertKuhlmann (talk | contribs)I've drawn the MK2a heatbed as an SVG-file (Inkscape), so anyone can create their own heatbed with the toner transfer method, without the need to use a PCB-layout-software. Most regular Laserprinters don't support a printing range of 214mm x 214mm. You c
  • You cannot overwrite this file.
The following 4 pages link to this file:
Metadata
