File:OHM OpenY.zip
Revision as of 21:41, 6 December 2012 by Jib5181 (talk | contribs) (uploaded a new version of "File:OHM OpenY.zip": added bed springs)
OHM_OpenY.zip (file size: 57 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
STL files needed to construct the Open Y
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 20:43, 28 February 2013 | (57 KB) | Dms5982 (talk | contribs) | updated version of OpenY_8mm Belt Harness_1off, flipped openY_arm45 to avoid slic3r error |
20:06, 15 January 2013 | (56 KB) | Jib5181 (talk | contribs) | OpenY_45 arm STL updated | |
21:41, 6 December 2012 | (61 KB) | Jib5181 (talk | contribs) | added bed springs | |
21:40, 6 December 2012 | (50 KB) | Jib5181 (talk | contribs) | STL files needed to construct the Open Y |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
