File:SpoolHead Cutter 4.PNG
Revision as of 04:38, 20 February 2010 by Jbayless (talk | contribs) (Close-up view of SpoolHead cutting device: Rotating cross-drilled rod inside cross-drilled tube.)
Original file(1,035 × 449 pixels, file size: 93 KB, MIME type: image/png)
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current04:38, 20 February 2010Thumbnail for version as of 04:38, 20 February 20101,035 × 449 (93 KB)Jbayless (talk | contribs)Close-up view of SpoolHead cutting device: Rotating cross-drilled rod inside cross-drilled tube.
  • You cannot overwrite this file.
The following page links to this file:
