File:SpoolHead Square.JPG
Revision as of 03:05, 19 April 2010 by Jbayless (talk | contribs) (A wire square printed using the SpoolHead. A note about print quality: The plastic print quality in this photo is terrible; however, the print quality on the wires is quite good. The cause of the poor plastic print is excessive vibrations on the extr)
Size of this preview: 800 × 571 pixels. Other resolutions: 320 × 228 pixels | 1,479 × 1,055 pixels.
Original file (1,479 × 1,055 pixels, file size: 266 KB, MIME type: image/jpeg)
A note about print quality: The plastic print quality in this photo is terrible; however, the print quality on the wires is quite good. The cause of the poor plastic print is excessive vibrations on the extruder, as all of the screws holding the motor in place had shaken loose. The square is merely a test piece, though, and the effect was mostly cosmetic, so we decided to proceed with the wire printing anyway.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 03:05, 19 April 2010 | 1,479 × 1,055 (266 KB) | Jbayless (talk | contribs) | A wire square printed using the SpoolHead. A note about print quality: The plastic print quality in this photo is terrible; however, the print quality on the wires is quite good. The cause of the poor plastic print is excessive vibrations on the extr |
- You cannot overwrite this file.
File usage
The following page links to this file:
