OpenX
Revision as of 17:43, 2 February 2011 by Buback (talk | contribs)
OpenX
Release status: experimental
a minimal X carriage that uses bearings
GPL
The Goal here is to create a lightweight, minimal x carriage. the carriage will have a large central opening to facilitate various hot end designs, and provide enough room to insulate the hot end.
I find the default Sells carriage too bulky and confining. I also hate that the mounting points are above the rails, which means the whole carriage has to be disassembeled if you want to get to the extruder. It also has a lot of mass, and much of the structure is bellow the rails, putting it close to the hot end and risking warping from the heat plume.
here's what i came up with:
Those m4-40 bolts are all that i had that would reach.
In order to make construction easier, i didn't oppose the bearing by 120 degrees each, instead opting for a 0, 90, 210 degree config.
A side effect of this configuration is that the carriage can clip on and off of the rails easily with minimal disassembly. only the undercarriage bearing on the other rail has to be loosened.
pictures and files
here are some pictures of the individual parts along with the files: (Modeled in sketchup. I'll put up stl's after I have it finalized and printing.)
you can follow my progress in the forum here. Please make suggestions!
OpenX Arm.png File:OpenX Arm.skp
OpenX Carriage.png File:OpenX Carriage.skp
OpenX Undercarriage Bracket.png File:OpenX Undercarriage Bracket.skp
Variations
It was requested i make up an Arm bracket with only one bearing.
OpenX Arm Single 210.png File:OpenX Arm Single 210.skp
It was also requested i beef up the undercarriage bracket, making it into a sickle-like shape. I still need to model this up and so will post this later
