P2f
Revision as of 02:01, 1 March 2013 by Voicevon (talk | contribs) (Assembly it)
300
YesRap P2F is a completely new 3D printer, based on Prusa i3, MendelMax, Ultimaker, Open Rail, etc. Thank all of them!
Overview
P2F is a 3D printer designed by YesRap in China. The completely redesigned main frame is constructed using laser cut plywood. The linear bearing system, based on Open Rail and MakerSlide, is also completely redesigned using laser cut steel plates, bent and mounted on plywood frame. The expected initial release is March 2013.
Main Improvements
  1. Easy and fast assembly ------ in 5 hours for new users
  2. Light weight -------- 6.5kg, so lower shipping fee
  3. No smooth rods ------- no need of lubricant grease
  4. High speed ----------- travel = 300mm/s print = 200mm/s
  5. Low noise-------------  ??db
Parts List
Electrical Parts
Quantity Part Picture
1 Sanguinololu 1.3A + USB or Bluetooth
1 DC Power Supply 350W 12V 29A
1 Heated Bed
Mechanical Parts
Plywood Parts List
1 FrameY
1 FrameZ
2 Frame_Back side
2 Frame_Bottom side
1 Frame_Top
Steel Parts List
1 FrameX
Aluminum Parts List
1 Motor Y Mount
6 YesRail(R)
Additional Parts List
1 Extruder
1 Hot End
1 Borosilicate Glass
1 BudaschNozzle V1.1
Assembly it
Main Frame
Order todo Picture
1 cross frame_Z and frame_Y
2 insert two back side
Bottom Frame
Order todo Picture
1 Mount Y motor
2 Mount Y-home sensor
3 Mount Y-home sensor
4 Mount AC power socket to left bottom
5 join two bottom peaces and Y-motor
6 join two bottom frame to main frame
Mount YesRail
use m3*25 screw,
Order todo Picture
1 Mount YesRaail on Y
2 Mount YesRail on Z
Links
[1] A video showing the printer printing using ABS.
