RAMPS 1.7
Revision as of 04:41, 25 June 2018 by MrAlvin (talk | contribs) (Bill Of Materials)
Version specific info
RAMPS 1.7 | RAMPS 1.6 | RAMPS 1.5 | RAMPS 1.4.4 | RAMPS 1.4 | RAMPS 1.3 | RAMPS 1.2 (RAMPS 1.2 old) and older
RAMPS 1.7
Release status: Prototype
RepRap Arduino Mega Pololu Shield Arduino MEGA based modular RepRap electronics.
Summary
I am working on developing a RAMPS version that will allow TMC2130 drivers (using SPI) to be used, simply by moving some jumpers.
This is a link to a forums discussion about the board
The board is also meant to be usable with 32-bit processors that use 3V logic, like the Arduino DUE
Sources
Design files
As soon as I know that the design actually works, all files I have/use will be made available.
Bill Of Materials
A (partial) list of components that are used for this board.
ID Description Quantity Digikey Part Number (Description) Other supplier Notes
C1 Low ESR 100uF/35V 6 PCE4554CT-ND  ? 6.60mm x 6.60mm
C2 10uF/16V 3 399-17336-1-ND  ? 4.30mm x 4.30mm
C3 1-10uF / 6V / 0805 1 CAP CER 10UF 6.3V X5R 0805 ebay option  ?
C6 100nF / 6V / 0805 2 CAP CER 0.1UF 50V X7R 0805 ebay option  ?
C7 1-10uF / 35V / 0805 1 CAP CER 10UF 35V X5R 0805  ?  ?
C8 10uF/35V 1 732-8503-1-ND  ? 4.30mm x 4.30mm
Q3,Q4 IRLB3034
N-channel mosfet, 2 mili Ohm, 40V
2 IRLB3034PBF-ND  ? TO-220
Q1, Q2 IRLR7843
N-channel mosfet, 4 milli Ohm, 30V
2 IRLR7843PBFCT-ND  ? TO-252
N AO3400
N-channel mosfet, 33-52 milli Ohm, 30V
4 785-1000-1-ND  ? SOT-23
IC 74LS125 1 SN74LS125ADR ebay option  ?n
IC 24LC256 1 24LC256 ebay option  ?n
S1 4-pin 7.62mm screw terminal 1  ?d  ?o  ?n
S2 2-pin 5.08mm screw terminal 4  ?d  ?o  ?n
R1 100K 0805 10  ?d  ?o  ?n
R2 10K 0805 6  ?d  ?o  ?n
R3 4K7 0805 13  ?d  ?o  ?n
R4 2K2 0805 7  ?d  ?o  ?n
R5 10R 0805 6  ?d  ?o  ?n
R6 1K 0805 1  ?d  ?o  ?n
R7 680R 0805 1  ?d  ?o  ?n
E1-3 Green LED 0805 3  ?d  ?o  ?n
E4 Red LED 0805 3  ?d  ?o  ?n
E5 Yellow LED 0805 1  ?d  ?o  ?n
D2 diode 1N5822 TH 1 1N5822G ebay options Any 3-10A diode will do fine
D1, D3-D5 diode 1N4007 smd 4 DIODE SCHOTTKY 30V 1A DO214AA ebay options Housing: DO-214AA / SMB
Diode 1N5819 / S4 - SMD 5 Digi Options ebay options  ?n
Fuse options
F1,F2 Auto blade fuse / 1808 2  ?d  ?o  ?n
F3 TH fuse / 0603 fuse 1  ?d  ?o  ?n
F4,F5 1206,24V, 2A poly fuse 2  ?d ebay example  ?n
Pin headers
2p male txt  ?  ?d  ?o  ?n
3p male txt  ?  ?d  ?o  ?n
8p female txt  ?  ?d  ?o  ?n
2p female txt  ?  ?d  ?o  ?n
