Aluminatus TrinityOne Software Electronics
Aluminatus TrinityOne Documentation
Software
Download The Software
Slicing Software
- Download Slic3r. This is the software you'll use to convert your 3D model into G-Code. G-Code is what the Aluminatus uses to actually print your model.
- Alternatively, download KISSlicer. Note, this is less widely used by the 3D Printing community
Printer Control/Gcode Reviewing Software
- Download Pronterface. This software allows you to print something over USB and manually drive around your bot.
- Download Repetier Host. This alternative software also allows you to print something over USB and manually driver around your bot. But it also features a fantastic G-Code view to allow you to verify the G-Code before printing.
Firmware Updating Software
- Download Arduino. This allows you the open the firmware (Marlin), make changes, and upload new firmware to your bot's electronics.
- Download Marlin. This is the actual firmware files for your electronics. It has been preconfigured and is ready to go.
- Place the Marlin folder in the Arduino directory for it to be recognized.
- To flash the firmware to your electronics, refer to this guide.
Electronics
RAMPS
Necessary Additional Steps
Ensure no missed steps
- If you are experiencing missed steps, ensure the Pololu stepper drivers are set to the appropriate current.
- Correct stepper voltage is .33v for X&Y, .42 for Z, .475 for E.
- If you are skipping Y-SIMO steps when printing at higher speeds, lighten the aluminum "dogbones" and the x-plate by drilling a few dozen lightening holes. You can easily remove as much as 150g from the mass of the y-carriage, and this will greatly reduce incidence of Y-skips.
Provide better cooling for Pololu stepper drivers
- If LCD panel is installed, blocking fan flow
- Re-locate 40 mm fan to one side, blowing across all driver chips.
- Upgrade fan if desired (a 60 mm fan will fit).
- Current best practice recommends not installing heat sinks on these chips.
Verify correct extrusion direction
- Some printers shipped with a mirrored extruder mount piece (printed). This causes the extruder to run "backwards" since the motor is mounted on the other side.
- The simplest fix is to remove, flip, and reinstall the 4-wire connector connected to 'E0' on the RAMPS board.
- POWER OFF your machine before doing this or you will destroy electronics
- This may also be corrected in the firmware.
- Look in the Configuration.h file of Marlin for the line: #define INVERT_E0_DIR false
- Change it to: #define INVERT_E0_DIR true
- (It might be the other way, you just need to make it "true" or "false", whatever isn't stated there currently)
- Now reflash Marlin to your electronics. Refer to this guide for help.
- Note that if a new, correct extruder mount is printed, the direction will need to be re-reversed.
Helpful Additional Steps
Address X-endstop electrical noise issue
- Re-route X-endstop wiring such that it does not run next to any stepper motor wiring
- Alternatively, add a 10-100nF ceramic capacitor on the RAMPS side of the wiring (this may be jammed into the connector, which would not require soldering)
- Alternatively, add a 4700-ohm resistor to the x-endstop wiring (which side?). Some owners have made cable extensions with a resistor, eliminating the need to cut stock wiring.
- Alternatively, re-wire X-endstop and/or stepper motor wires using shielded, twisted cable.
- Alternatively, unplug the X-endstop switch at the RAMPS board and ensure that no homing process is inserted into the G-code when printing.
- Note most of these may be combined.
Verify functionality of the SD card slot
- If when inserting your SD card you get a 'card inserted' message, but going to the card menu on the LCD gives a 'no card' message:
- There is a cold solder joint on the panel. Re-solder anything that looks cold until you solve the issue.
- If when inserting your SD card you do not get a 'card inserted' message:
- There is a small switch (leaf spring style) on the side of the reader that may have been damaged. Check for misaligned parts, adjust with a pin or other small tool.
Helpful Firmware Tweaks
- Increase the PID_FUNCTIONAL_RANGE in the config.h file of Marlin to 20.
- The default for the value is 10. With a 24 V system, 10 degrees for the hotend is about 1 second when initially heating up so it would overshoot a lot.
- Make sure your PID is tuned.
- Values I like:
- Send M301 P12.5 I0.18 D12.0 to update your hotend PID settings. (Send these commands from Pronterface or something similar)
- Send M304 P125.0 I0.3 D300.0 to update your Bed PID settings.
- Now send M500 to save the PID settings to EEPROM.
- Values I like:
