CNC winding
From RepRapWiki
CNC winding
Release status: experimental
[[Image:|center|190px]]
Description building a printable cnc controlled winding machine for rovings
License GPL 2.0
Author Mindfab
Based-on Delta
Categories CNC machines
CAD Models none
Idea
This is a project which will create a CNC controlled filament winding machine. The machine can also be used as a coil winder, but the focus is on filament winding. The machine is build by 3D printable parts and cnc parts... Later on, a software toolchain will be created... I call that project YA*wM which stands for YetAnother(Roving)windingMachine.
Specification
  • turn-based winding machine, the core rotates
  • 2 degrees of freedom (C and Z direction), that means, the core rotates (C-axis) and the shuttle can be shifted (Z-axis)
  • the core can be up to 1m long and 0.2m in diameter
  • will use a Nema23 for C axis and nema17 for z axis
  • the controller will be based on a modified Gen7 electronics, and will use a modified firmware
  • the software will be some python scripts generating gcode which can be send to the controller board
Construction
Z-Axis
  • uses 16mm steel rods and 16mm linear bearings
  • belt driven like a standard mendel x carriage...
  • the figures shows the axis in an early stage
