Easy electronics
From RepRapWiki
Infobox info icon.svg.png Not Open Source
As stated in the RepRap Wiki Policy, a wiki page that describes a product offered for sale must provide source files for that product.
This page is missing at least these item(s)
  • Does not provide files sufficent to make a copy, and does not provide a license.
There might be more items missing.
If you want to help improve this design, please find source files for these missing items and upload them to this wiki, or link to the repository containing them.
In accordance with the Deletion policy, an admin will review this page in about three weeks to determine if it should be removed or not.
If source files are not uploaded by the proposed delete date, this page will be removed from the wiki.
Proposed delete date: {{{deletedate}}}
Questions about this tag can be addressed on this page's discussion page or on the Administration, Announcements, Policy forum.
Infobox info icon.svg.png This page is flagged as Advertising.
This page is found to exist for the sole purpose of Advertising, This page will eventually be removed. Reason: Not Open-Source Proposed removal date: March 1st 2017 Please use the discussion page for any questions or comments regarding this notice
STB
Description Release Version 0.9
License GPL 2.0
Author STB
Based-on Sanguinololu, ATmega1284p
Categories Electronics, Development, Mendel Development
External Link none
Campaign on Indiegogo
easy electronics
Overview
The RepRap easy electronics is a powerful printer electronics for 2 Extruders, heated printbed and many more in one single board. Developed for people who want to spend their time for designing & printing and not for configuring several addon PCBs with the risk that nothing fits together either electrically or mechanically. Curious about it? Read on...
The RepRap easy electronics is suitable for beginners up to enthusiast reprappers. You can start with single extruder 3D-printer and later extend it to a high-end dual Extruder 3D-printer with heated bed etc., this electronics grows with your printer.
The electronics features
  • Operates from a single 12..24V DC supply
  • On board protection fuses for Hotends and Heatbed
  • 5 (replaceable) stepper controllers supporting 1/1 step .. 1/16 step
  • Automatically controlled stepper driver cooling-fan output
  • Dual extruder
  • Heated printbed
  • Hotend fan control
  • USB interface
  • Stand alone printing from micro-SD card
  • 128x64 dots graphic LCD display (depends on version, all versions are upgradable)
  • User menu navigation with click wheel
The electronics basic functionality is Sanguinololu compatible. It works with most of the printer firmwares. For the graphical user interface and click wheel user menu ErikZalm's Marlin is necessary it has built-in native support for the RepRap easy electronics.
Cabling
The connectors to the printer hardware are grouped by functions. This means all necessary connections to the Extruder are grouped together on the easy electronics pcb. So there is no need for searching. Extruder motor pinheader, Extruder thermistor input, Extruder heater output are grouped side by side. The same for the axis Motors and endstop connectors all are organized in groups, so for example the x-endstop connector is next to the x-motor connector and nowhere else. The status of all outputs (hotend, hotbed ....) is visualized by LEDs on the PCB.
Power Supply Requirements
The easy electronics needs only one supply voltage for it. It can be operated from any voltage between 12V..24V. There is no jumper chaos for the supply-options like on other boards where depending on which supply voltage it is operated up to 5 selections must be made before the power supply can be connected. No jumpers means also fewer errors/damage during the setup of the printer. The electronics is fused by standard fuses that you know from your car, easy replaceable and cheap.
Bootloader
The easy electronics has an arduino-compatible built-in bootloader. Modify your printers firmware inside the arduino framework and upload it by simply using the arduino tools via USB.
Micro SD-Card Socket
Simply load your gcode file on a micro-SD card. Select it via the graphical user interface and start to print. There is no need for a host computer.
Source files
  • PCB Eagle data
http://www.avboard.de/Bilder/Sanguino_STB_V51_panel.brd
  • Partlist
http://www.avboard.de/Bilder/Sanguino_Nutzen_STB_V5_BOM_v2.xlsx
Contact
Contact STB
orders
