$80,000 Gada Prize announced for the first team to build a better RepRap.
Extruder SNAP V1
From RepRapWiki
This document is completely theoretical at this point in time!
Extruder Controller SNAP Protocol Version 1
This is the second version of the thermoplastic extruder protocol. It accepts various commands relating to controlling a single thermoplastic extruder.
API
The following commands are in addition to the globally required commands on the main modules page.
Is Empty?
Parameters:
  • 1 byte status (0=full, 1=empty)
Returns:
  • Nothing
Set heat
Parameters:
  • 1 byte low heat (pwm)
  • 1 byte high heat (pwm)
  • 2 byte target temp (celsius)
  • 2 byte max temp (celsius)
Returns:
  • Nothing
Get temperature
Parameters
  • Nothing
Returns:
  • 2 byte temp (celsius)
Set cooler
Parameters
  • 1 byte pwm
Returns:
  • Nothing
Free Motor
Parameters:
  • Nothing
Returns:
  • Nothing
Motion control ideas:
we need to figure out how we want to do motor control in the next version of the protocol. should we use the 'blind' method of a normal DC motor, or should we use something with more precise positioning information like a stepper or servo?
motion control #1 (dc motor):
Move Forward
Parameters:
  • 1 byte pwm
Returns:
  • Nothing
Move Backward
Parameters:
  • 1 byte pwm
Returns:
  • Nothing
motion control #2 (stepper/servo):
Set Speed
Parameters:
  • 2 byte (rpm, rph, hz?)
Returns:
  • Nothing
Get Speed
Parameters:
  • Nothing
Returns:
Set Position
Parameters:
  • 4 byte position
Returns:
  • Nothing
Get position
Parameters:
  • Nothing
Returns:
  • 4 byte position
Set Target
Parameters:
  • 4 byte target
Returns:
  • Nothing
Get Target
Parameters:
  • Nothing
Returns:
  • 4 byte target
Personal tools
interaction
