Mf70 repstrap
From RepRapWiki
MF70 RepStrap
Release status: unknown
Description MillStrap based on Proxxon MF70 mill
License GPL
Author Krefelder
Based-on Mendel
Categories Category:MillStrap
CAD Models none
External Link none
This Page Shows how to add an extruder to a Proxxon MF 70. CNC support was added to the mill with a commercial DIY Kit.
With the kit that included electronics it is possible to do milling, automated drilling, pcb milling and engraving based on EMC (LinuxCnc) or Arduino with GRBL.
The final step will be to use have a MillStrap machine.
1. Buy a MF_70 drill machine
2. Upgrade with CNC kit
With EMC you are able to do drilling, milling and engraving.
Drawbacks: - you need Ubuntu LTS 10.04 with realtime extensions on a computer with parallel port (subd-25)
This step was successfully executed
3. Create an Arduino based controller
To do a little bootstrapping, you can create your own controller for the machine. The machine is already supporting drilling anc pcb milling with EMC, so it is possible to create the pcb. The needed tools are: - Engraving Bit (V-Carve) - drill bit
This step was successfully executed. The machine runs fine with GRBL firmware on the arduino. The software used to run the machine is:
- PuTTY (direct connection to virtual serial port)
- GRBL controller
The machine can be operated from Windows machine now. Realtime Linux is not needed anymore. All major operating systems are supported: Linux, Windows, MacOS
4. Mount an Extruder to the machine
An extruder is mounted to the machine, so that the mechanical part of the MillStrap is complete. The Extruder will be connected to the generation-7 electronics later.
This step was successfully executed with a prototype made from wood:
5. Create and modify a generation-7 electronics to drive the machine
My expectation is that the polulu stepper drivers on the Generation 7 Electronics are able to drive the stepper motors of the Mill. But as the steppers of the mill are wired to the Uni 1500 Electronics, I will save the money for additional polulu steper drivers and will wire the step-Direktion pins of the microcontroller to the sub-d 25 connector to be able to reuse the existing electronic-
This is work in progress
References:
Manufacturer of the mill Http://www.proxxon.de
Manufacturer of the Cnc kit: Http://www.usovo.de
GRBL Controller: http://www.zapmaker.org
