Mini panel
From RepRapWiki
Mini Panel is a mini 12864 panel for 3d printer.
Mega controller
Release status: Working
Description Single board solution, Remix of Arduino mega and RAMPS
License GPL
Author Makerlab
Based-on nothing
Categories Electronics interface with display
CAD Models none
External Link none
Summary
Connecting to Ramps
Mini Panel can be connected to the Ramps. But need a little modification for Ramps. Mini Panel use AUX-2 and AUX-3 in Ramps. But the AUX-2 pin1 and pin2 should be like the following picture. MiniPanel ramps.jpg
Connecting to Mega controller
Mini Panel is designed for {Mega controller},
Hooking up the LCD display is pretty easy, just follow the wiring diagram below. Note that the connector is turned 180 degrees in the image. The trimpot on the board sets the contrast of the LCD, if you don't see anything, you probably need to turn this.
Files
How to get it
