Rather Blue T-Slot Bot
From RepRapWiki
These are good resources for creating wiki pages.
Very Messy Example and Columbus
--Sebastien Bailard 07:23, 10 September 2010 (UTC)
Example Development
Release status: unknown
Description documenting a generic tool/artpiece
License GPL
Author Have Blue
Based-on Sui Generis
Categories T-Slot,Has Files,Files Missing, Needs Render
CAD Models none
External Link http://haveblue.org/
 Click the red link to upload an image file!    :D
Rather_Blue-File-Name SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Rather_Blue-File-Name CAD FILES FOR PARTS These are CAD files for each part. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Rather_Blue-File-Name EVEN MORE FILES These are are even more files. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)|-
Rather_Blue-File-Name SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
Please edit this and click the links to put in your own files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
Bill of Materials/Parts List
I chopped the pieces to rough length on the big horizontal bandsaw at work, and then took them home to machine the ends to the final precise lengths. After tapping the holes in the ends to 5/16″-18 and drilling access holes in strategic locations (all detailed in the prints contained in the set of plans available on Fine Line’s site), the extrusion pieces were complete. A trip to Speedy Metals netted me the cold rolled steel, which I also drilled out on the mill. With stepper motors on the way from Keling, bearings from VXB, ballnuts and ballscrews from McMaster-Carr and couplers from Enco, it seemed like a good time to at least start assembling the base.
Many of the builds that I’ve seen of this design include additional bracing in corners. The framing itself is quite stout and I don’t intend to do any metal cutting with the machine, but more rigidity never hurts on a machine tool, so I used some aluminum angle on the inside corners. I ran out of screws, so the base isn’t yet quite fully assembled, but at least I have a sign of progress.
More Examples
