Stepper Expander
From RepRapWiki
Infobox info icon.svg.png Not Open Source
As stated in the RepRap Wiki Policy, a wiki page that describes a product offered for sale must provide source files for that product.
This page is missing at least these item(s)
  • No sources at all.
There might be more items missing.
If you want to help improve this design, please find source files for these missing items and upload them to this wiki, or link to the repository containing them.
In accordance with the Deletion policy, an admin will review this page in about three weeks to determine if it should be removed or not.
If source files are not uploaded by the proposed delete date, this page will be removed from the wiki.
Proposed delete date: {{{deletedate}}}
Questions about this tag can be addressed on this page's discussion page or on the Administration, Announcements, Policy forum.
Stepper Expander
Description For when you need more stepper drivers on your printer.
License CC-BY-NC-SA
Author Kenneth Weiss
Based-on Sui Generis
Categories RepRap Diamond Hotend, Stepper motor drivers, Electronics, RAMPS
CAD Models none
External Link www.reprap.me
Intro
The Stepper Expander X1/2/3 is designed as an easy way to add more stepper drivers to your 3D printer and other electronics.
It can also be used to repair / patch-up boards where the stepper driver chip is SMD soldered on the board like Melzi, Printrboard and so on....
Stepper Expander X1
Stepper Expander X2
Stepper Expander X3
It is possible to set the microstepping for each stepstick. This is done via the solder jumpers called MS1, 2, 3. By default the pads of these solder jumpers are connected (On) but you can cut the thin traces individually with a sharp tool thereby disabling each of them. If needed at a later point the solder jumper pads can be reconnected using solder.
Pinout
X1 X2 X3
n/c EN STP DIR +5V
n/c EN STP DIR GND
EN STP GND +5V
n/c DIR GND +5V
66 44 64 59 +5V
65 42 40 63 GND
58 57 GND +5V
0 1 GND +5V
RAMPS pin numbering
Notice: the very first production batch, identified by green PCB (as opposed to the newer black version) counter-intuitively has the text VMOT placed next to the negative power terminal. This is fixed in newer batches as the VMOT label has been moved next to the positive side of the screw terminal.
As An Expansion Board
Using RAMPS
See Adding more extruders for an easy guide to adding a third extruder motor to RAMPS
RAMPS capable of running 3 extruder motors.
RAMPS capable of running 4 extruder motors
Repair Jobs
There are many different 3D printer control boards and variations thereof but the general steps are the same.
PrintrBoard
Identify the contact points for DIR, STEP and ENABLE.
As the traces can vary from one board version to another it's recommended to make the connections directly to the MCU unless there are other obvious alternatives.
The 5V and GND are usually easy to find at the capacitors.
Cut the signal traces to the defective stepper driver so it won't make any trouble in the future.
Take a 10 wire ribbon cable with a 2X5 female pin header connector and cut it to your desired length.
For the Stepper Expander X1 only wire's 1, 2, 3, 5 and 7 are used.
Wire 1 = 5V Wire 2 = GND wire 3 = DIR Wire 5 = STEP Wire 7 = EN
Solder the wires to the right connections.
It's a good idea to secure the wires to the board with hotglue or similar to prevent them from breaking off due to vibrations.
Connect the stepper motor to the Stepper Expander and the power terminals on the Stepper Expander to the main board's power input and you should be good to go.
Melzi
First remove any components that are causing any problems from the stepper driver you want to replace.
Where to get it
