Talk:RepRapPro Mendel y axis assembly
Mounted Toothed Pulley
The instruction "These simply push-fit onto the motor shaft and don't need a set screw - see below." does not explain which way on to put it on. I have not built a 3D printer before so this may be obvious later in the build, but not easily remedied if I were to use superglue as suggested. A clarification would be greatly appreciated.
John Cummings 13:43, 14 February 2013 (UTC)
