I adjusted the layer height as suggested and my lines came out straight this time. Separating layers at the top of the funnel of
the fan mount and at the bottom end where the curve is. My bed temperature actually came up to 92 degrees, which is still 20 degrees to low, but at least the print stayed put, probably thanks to the Kapton. I do not know if the low bed temp accounts for
the bottom separating layers, but that does not explain the top of the funnel, unless the fan blowing on my Ramps board is
causing that problem. Pics: [
www.flickr.com]
I will do a proper calibration of Sfact to see if this will clear up the problem...otherwise progress!
Thanks everyone,
Bob
