I've got a Prusa hardware kit from reprapkitstore via ebay.
top & bottom plates are pre cut & drilled.
The bottom plate is 140mm wide (per the visual instructions) but 240mm long (visual instructions say 225mm). Holes are 5mm in from the short (140mm) edge & 8mm in from the long edge.
top & bottom plate holes align ok.
Is the 240mm length ok, or do I need to hacksaw 15mm off one end & re-drill the holes?
(I would then have to re-work the top plate to match)
Or should it work ok as is?
Thanks in advance
Ok I went ahead anyway & it looks ok.
Prusa build continues...
Mike
Edited 2 time(s). Last edit at 11/11/2011 11:53AM by 3D2B.
