PID control September 08, 2010 12:07AM |
Re: PID control September 08, 2010 04:42AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: PID control September 08, 2010 04:49AM |
nophead
I don't understand why my "vitreous enamel resistor pushed into a small block of aluminium design" is not the recommended default. It isn't expensive or hard to make, especially compared to making the nozzle.
Re: PID control September 08, 2010 04:54AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: PID control September 08, 2010 05:05AM |
Re: PID control September 08, 2010 05:14AM |
Re: PID control September 08, 2010 06:13AM |
YES, but most of us don't have a lathe and therefore only the brave attempt making their own nozzle using just a drill press.
I have purchased some vitreous enamel resistors but with only a drill press have not attempted to make the needed block.
The nichrome wire is fairly easy and works pretty well but I do like your solution better. thumbs up
Re: PID control September 08, 2010 06:49AM |
nophead
RepRap is distributed mass production. That means the production environment is total uncontrolled. Which means that the designs have to be very robust indeed to have a high success rate.
Re: PID control September 08, 2010 09:02AM |
Re: PID control September 08, 2010 02:28PM |
Re: PID control September 13, 2010 12:52PM |
Re: PID control September 16, 2010 05:54AM |
Re: PID control September 17, 2010 04:36AM |
Re: PID control September 17, 2010 07:01AM |
Re: PID control September 17, 2010 07:40AM |
Re: PID control September 17, 2010 08:30AM |
Re: PID control September 17, 2010 10:02AM |
Re: PID control September 17, 2010 10:11AM |
Re: PID control September 17, 2010 11:45AM |
Adrian Bowyer
It's now a parameter in the firmware. You set the proportional band
in deg C. Setting that to 0 gives bang-bang.
Re: PID control September 17, 2010 09:29PM |
Re: PID control September 17, 2010 11:56PM |
Re: PID control September 20, 2010 01:38AM |
Re: PID control September 20, 2010 10:36AM |
Re: PID control September 20, 2010 11:29AM |
Re: PID control September 23, 2010 01:10AM |
