Re: 1.75mm Filament vs 3mm Filament June 26, 2014 01:57PM |
Most agreed. If it's any more than 0.1mm I'd never again buy from them, percentage aside.Quote
Ralph.Hilton
10% is far too high. I see no reason to use a supplier who can't guarantee 5% .Quote
sheepdog43
Another problem is filament precision, anything over 10% out of spec is considered problematic. On 3mm, this is .3mm that is a HUGE deviation and very easy to stay within spec, on 1.75mm, you are allowed only .17, which is troublesome for some manufacturers. I have had some 1.75mm filament that was .24mm out of spec and jammed my bowden tube so bad I had to hammer a stiff metal rod into the tube to get it out.
Re: 1.75mm Filament vs 3mm Filament June 26, 2014 06:28PM |
Re: 1.75mm Filament vs 3mm Filament June 26, 2014 08:24PM |
Re: 1.75mm Filament vs 3mm Filament June 26, 2014 10:37PM |
You're welcome,Quote
andyinyakima
So sheepdog43, you think 1.75 mm jhead would be a better place to start and compare results with the one I have now?
I totally agree.Quote
Ralph.Hilton
Re: 1.75mm Filament vs 3mm Filament June 27, 2014 07:38AM |
Re: 1.75mm Filament vs 3mm Filament June 27, 2014 08:29AM |
I would pay with Paypal and use their dispute procedure. Also order a small quantity trying filament from a new supplier.Quote
Ralph.Hilton
Unfortunately I've seen many "guarantee it", but won't back it up when they fail to reach those specs. The company who jammed my bowden laughed and blew me off when I complained. This same company later asked me to make prints for them because they lack a printer, despite the fact that they claim to use the filament in their own printers and blame customers for all filament failures. There are some real sleezeballs out there.
Re: 1.75mm Filament vs 3mm Filament January 15, 2016 03:07AM |
I believe you are confusing pressure with force.Quote
Sublime
It seems that everyone thinks that 1.75mm takes less force but as far as I understand this is not true. A certain volume of plastic going through a certain size hole at a certain rate takes exactly the same pressure regardless of the filament input size. Or to put it simpler, the nozzle diameter determines the pressure required to extrude not the filament.
Re: 1.75mm Filament vs 3mm Filament January 15, 2016 09:46AM |
mbrembati
Sublime
I agree that the pressure depends on the nozzle diameter, but the force you need to push the filament is Pressure x Filament Section Surface. As S = Pi x (Wire Diameter/2)^2, the force you need to apply to the wire is (3/1,75)^2= 2,94 times higher with 3mm wire.
Re: 1.75mm Filament vs 3mm Filament January 16, 2016 01:33PM |
Re: 1.75mm Filament vs 3mm Filament January 16, 2016 02:42PM |
