Possibility of powering Sanguinololu via standard DC power brick? August 29, 2011 03:47PM |
Re: Possibility of powering Sanguinololu via standard DC power brick? August 29, 2011 04:24PM |
Re: Possibility of powering Sanguinololu via standard DC power brick? August 29, 2011 05:17PM |
Re: Possibility of powering Sanguinololu via standard DC power brick? August 29, 2011 05:31PM |
Re: Possibility of powering Sanguinololu via standard DC power brick? August 29, 2011 10:33PM |
Re: Possibility of powering Sanguinololu via standard DC power brick? September 24, 2011 08:12PM |
Re: Possibility of powering Sanguinololu via standard DC power brick? September 24, 2011 08:57PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Possibility of powering Sanguinololu via standard DC power brick? September 25, 2011 02:56AM |
Admin Registered: 17 years ago Posts: 7,879 |
I was under the impression that the advantage of using higher voltage/less current with a motor gives you a cooler running motor. Is that not the case?
