I'm building my first RepRap and there is a problem with the heaters, I have searched for answer but not found anything that could solve my problem exactly.
I have RAMPS 1.4 with Sprinter and I have pronterface to connect to the printer. The motors are working great, I get a readout on the thermistor after a lot of headache but the heaters are not heating up.
I have two 6.8 Ohm heating resistors that I have verified and they do heat up if connected straight to a 12V supply but they do not heat up when I ask pronterface to set temperature, what I get from pronterface is: T:25 @:0 B:25. If I put a multimeter there are 0V over the terminals and 3.4 Ohm (which makes sense since the heaters are connected in series). (I do not have a thermistor for heated bed since I don't have a heated bed fitted on my printer at this time if that's any help).
My power supply is 12V and supply 40A, that should not be the problem.
Any suggestions of what I might be doing wrong?
Any help will be appreciated. Thanks,
Gisli Steinn
Edited 1 time(s). Last edit at 04/10/2012 07:13PM by Gislinn.
