cstudio Wrote:
> When I for first time started up heater everything
> seem OK, except that solder began melting on
> heating resistor.
Sounds like you have a short circuit across the resistor. Can you measure the resistance of it?
You only need a ~6 amp 12 V supply to run a RepRap without a heated bed, and ~16 amps with a heated bed. The heated bed alone can draw 9 - 10 amps depending on the manufacture, the hotend draws ~2 amps, and the motors about 3 - 4 amps together.
